17255 Discussions
Questasim INTEl EDITION counter simulation
GOMEZ_IT
Hello.
I'm using this vhdl code to make an 8 bit counter with enable. Quetasim Intel fpga does not increment the counter regularly (defined as variable).
It goes from 'X' to '1' and then it doesn't count anymore.
Where am I doing wrong?
The code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity COUNT8 is
port(
CLK : in std_logic;
EN : in std_logic;
DOUT : out std_logic_vector(7 downto 0)
end COUNT8;
architecture behavior of COUNT8 is
begin
-- notice the process statement and the variable COUNT
clk_proc:process(CLK)
variable COUNT:std_logic_vector(7 downto 0) := x"00";
begin
if rising_edge(CLK) then
if en = '1' then
COUNT := std_logic_vector((unsigned(COUNT)) + 1);
DOUT <= COUNT;
end if;
end if;
end process clk_proc;
end behavior;
roeekalinsky
Valued Contributor I
@GOMEZ_IT, I think you were right, this looks like a simulator problem.
I was able to reproduce your original observation, and it appears to be a bug in older versions of Questa, up to the version shipped with Quartus Pro 23.3.
The version of Questa shipped with Quartus Pro 23.4 doesn't appear to exhibit this symptom. Or at least not with this test case. But I don't know if this was a known bug that got fixed, or if the symptom just went away with other changes in Questa. That's something you should confirm with Intel and/or Mentor/Siemens.
For ease of testing, I modified your test case slightly to be able to run in a more minimalist command line mode, with console messages in lieu of waveforms. See attached zip.
Running this test case with all the simulators I currently have available to me I got the following results:
  • Questa from Quartus Pro 22.2: bad
  • Questa from Quartus Pro 22.4: bad
  • Questa from Quartus Pro 23.1: bad
  • Questa from Quartus Pro 23.2: bad
  • Questa from Quartus Pro 23.3: bad
  • Questa from Quartus Pro 23.4: good
  • Modelsim DE 2022.4: good
  • ghdl 4.0.0-dev: good
See attached log.txt for the above results.
-Roee
roeekalinsky
You're going wrong in using a variable declared in the process, whereas you should be using a signal declared in the architecture.  As you have it coded, with every entry into the process, i.e. every clock cycle, your variable is getting reinitialized to zero and then incrementing by one.
GOMEZ_IT
But why if i invert 2 lines of code the simulation works?
library IEEE;
entity COUNT8 is
port(
CLK : in std_logic;
EN : in std_logic;
end COUNT8;
begin
begin
if en = '1' then
DOUT <= COUNT;
end if;
end if;
end behavior;
roeekalinsky
I'm surprised to hear that it does.  I wouldn't think it should work in either case.  Looks like it's time to dig into the VHDL LRM for clarification on the exact semantics of variable initialization in a process.
roeekalinsky
Looks like I was mistaken.  An initial value at the variable declaration in the process takes effect at time zero, not at every entry into the process.  Learn something every day.
But now, the mystery deepens.  This explains why it does work, but it doesn't explain why your original example didn't work.  And in fact, simulating it both ways on my end, I see it work in both cases.  I can't reproduce your original result of it not working.
You didn't share your test bench, so I created a simple one to simulate it on my end.  I'm curious if the crux lies in how you're generating the inputs to this module, if there is some gotcha there somehow.  Can you please share your test bench code?
GOMEZ_IT
This is the bench code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity COUNT8_tb is
end COUNT8_tb;
architecture Behavioral of COUNT8_tb is
signal CLK : std_logic := '0';
signal EN : std_logic := '0';
signal DOUT : std_logic_vector(7 downto 0);
begin
-- Clock process
process
begin
wait for 5 ns;
CLK <= not CLK;
end process;
-- Stimulus process
process
begin
wait for 10 ns;
EN <= '1';
wait;
end process;
-- Instantiate the COUNT8 module
uut :entity work.COUNT8
port map (
CLK => CLK,
EN => EN,
DOUT => DOUT
end Behavioral;
GOMEZ_IT
I attach the questasim project also.
Can you launch the vsim from the questa/bin/ directory and open the project?
sstrell
It does not make sense why your changed code works.  As mentioned, COUNT gets reset every time the CLK changes so you can only count to 1 with this design, as you see in your original simulation.
For a counter, you should have a reset mechanism (synchronous or asynchronous control signal) and not initialize the variable in the variable declaration.
GOMEZ_IT
roeekalinsky
-Roee
GOMEZ_IT
Thank you all for the great support!!
roeekalinsky
P.S. Questa bug notwithstanding, I would still advise you to avoid this sort of coding style where you're relying on language features that are more obscure, even if technically correct. It makes your code less readable. And you also increase your risk of treading into areas where even the tools may not be 100% conforming and may not be well tested, as we saw here.
And also, separately, that's sound advice from @sstrell about using a reset signal rather than relying on variable initialization.  At least in RTL code that's intended for synthesis. Physical support for initial values varies between different FPGA device families and their various internal resource types.  And synchronization issues...  So there's plenty of opportunity to get yourself in trouble with that too if you're not careful.
SyafieqS
 I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
roeekalinsky
@SyafieqS,
Can you confirm whether or not this was in fact a known bug that was fixed in the Questa version that shipped with Quartus Pro 23.4?
-Roee
