Questasim vdel
skyviper
Questasim can't delete libraries using the vdel command.
Each time I attempt to use the vdel command (GUI or Tcl), I get the following:
vdel -all -lib tb_lib_path
# wrong # args: should be "compile"
TingJiangT_Intel
Please try this format:
vdel [-all] <library_name>
Use the library name instead of path, and don't use the '-lib' option.
skyviper
That doesn't work. Also, the GUI that does this for you uses this same syntax and doesn't work. I have been using Questasim for a long time and this always worked in the past and is how the manual tells you to do it. Can you get this fixed?
skyviper
Did you check to see if this even worked?
skyviper
Here is a screen show of the GUI attempting to do the same thing.
skyviper
More findings:
Now a simple substitution doesn't work:
A command like this doesn't substitute the value
    vlog -work $spi_dut_lib_path  -f $spi_dut_filelist
# ** Error: wrong # args: should be "compile"
# Error in macro ./run_scripts/run_spi_har.do line 222
# while executing
# "vlog -work $spi_dut_lib_path -f $spi_dut_filelist"
TingJiangT_Intel
Hi there, which version of Quartus and QuestaSim are you using. I didn't see the same error from my side.
skyviper
I think its time to escalate issues like this since they are are being ignored in this forum.
skyviper
The version is 24.2.0.40. I figured out that the tcl environment is broken and the GUI hasn't been updated to conform to the brokeness. I'm guessing that anyone that has been using QuestSim for a while isn't happy with the issues.
TingJiangT_Intel
Sorry, but I am unable to reproduce your issue. Could you try running it on another server and check if the error might be due to your system environment? If the same issue persists, please share your reproduction steps with me so I can analyze the problem further. Thanks.
skyviper
I tried this on 2 separate machines and it fails the same way.
skyviper
As part of this issue can you tell me why the -simulate command fails for qrun?
exec qrun -optimize -log [uplevel set reports_path] -outdir [uplevel set SIM_LIB_PATH] -top top_tb -o top_tb_out \
-makelib [uplevel set spi_dut_lib_path] -f [uplevel set spi_dut_filelist] -endlib \
-makelib [uplevel set dut_lib_path] -f [uplevel set dut_filelist] -endlib \
-makelib [uplevel set spi_tb_resuse_lib_path] -f [uplevel set tb_reuse_filelist] \
-vlog.options +define+[uplevel set SCOPE] -timescale=10ns/1ns -sv -end -endlib \
-makelib [uplevel set tb_lib_path] -f [uplevel set tb_filelist] -vlog.options -timescale=10ns/1ns -sv -end -endlib
This works:
eval vsim -work ./$SIM_LIB_PATH/$work_path -L ./$SIM_LIB_PATH/spi_dut_lib -L ./$SIM_LIB_PATH/dut_lib \
-L ./$SIM_LIB_PATH/spi_tb_lib -L ./$SIM_LIB_PATH/tb_lib top_tb_out {*}$vsim_opt
This doesn't:
exec qrun -simulate -log $reports_path -outdir $SIM_LIB_PATH \
-vsim.options -w $SIM_LIB_PATH/work -L ./$SIM_LIB_PATH/spi_dut_lib -L ./$SIM_LIB_PATH/dut_lib -L ./$SIM_LIB_PATH/spi_tb_lib \
-L ./$SIM_LIB_PATH/tb_lib {*}$vsim_opt -gui=int -end top_tb_out -script $SIM_LIB_PATH/sscript.run
skyviper
correction... "-w" should be -work" and it still doesn't work.
skyviper
I shared the steps in the screen capture. Regardless of how the command is run it fails. vdel -all -Lib name fails in the GUI and in Tcl.
Scripts that I ran in Questasim last year fail as well.
TingJiangT_Intel
Hi there, Are you using Questasim or Questa Intel?
Vdel is available in Questa Intel which I have tried to reproduce your issue. For Questasim, this issue may need to ask Questasim vendor.
skyviper
Lets stop the back and forth and have a conference call on Teams to allow me to show you again what is going on. I have sent you screen captures that show that I am using Intel products. Please send a link for the meeting.
Tony
TingJiangT_Intel
I've scheduled a meeting on Thursday from 2:30 PM to 3:00 PM Malaysia Time (MYT). You can join via the Teams link. Please let me know if this time works for you.
TingJiangT_Intel
Hi there, we tested the vdel function in questasim 24.1 with win10, and it works well.
Could you please provide your design to us for further investigating on your issue?
TingJiangT_Intel
BTW, I have submit this issue to the engineer. If any updates, we will inform you.
You can try to reinstall the Quartus (with Intel Questa), and make sure all antivirus, antimalware are turned off, as it may related to the software corruption,
TingJiangT_Intel
Hi there, to let you know, I just get the following response from the engineer team;
The following steps may be creating an error.
1. vmap rtest <library_path> : This step is creating the mapping with the name of rtest
2. vmap -del rtest : This step deletes the mapping done with the name of rtest. It means, Questa no more identify any library with the name of rtest
3. vdel -all -lib rtest: Here user is trying to delete the rtest library which no more exist. As logical link is deleted. User has to pass the full path of library now to delete it instead of rtest.
Alternative is to switch the sequence of step 2 and 3. Perform vdel first and then vmap -del
Let me know if you still face any problem.
