17263 Discussions
Question about Example 1-22 of Quartus Prime TimeQuest Timing Analyzer Cookbook
In Example 1-22 of "Quartus Prime TimeQuest Timing Analyzer Cookbook", the latency of clk_a and clk_b is specified. clk_a and clk_b are in the different clock_groups. However, if is normal that they are not used in set_input_delay and set_output_delay. Why should the latency and clock_groups for clk_a and clk_b be specified if they are used in the set_input_delay and set_out_delay?
Also
set input_max [expr $Td_max + $Tco_max]
set input_min [expr $Td_min + $Tco_min]
# Create the input delay constraints when clk_a is selected
set_input_delay
-clock virtual_source_clk_a
-max $input_max
[get_ports datain]
set_input_delay
-min $input_min
[get_ports datain]
Are there the differences in the clock paths missing in $input_max and $input_min?
