17261 Discussions
RAM inference not working for initialized RAM
obruendl
According to documentation RAM initialization should work in VHDL by simply adding an initialization value to the memory array.
https://www.intel.com/content/www/us/en/docs/programmable/683082/21-3/specifying-initial-memory-contents-at.html
However, In my code (see attached), this is not the case. Without initialization value (resp. with initializing all content to zero) the code infers 8kb RAM - so the syntax seems fine for RAM inference. As soon as I add any other initialization content than zeros, registers are inferred (not RAM).
I have attached my code containing both cases.
With line 109 uncommented, RAM inferrence works:
signal Mem_v : Data_t(Depth_g - 1 downto 0) := (others => (others => '0'));
With line 108 uncommented, RAM inferrence fails:
signal Mem_v : Data_t(Depth_g - 1 downto 0) := (0 => x"1234", 1 => x"5678", others => (others => '0'));
Why is RAM inference not working? What can I do to make it work?
FvM
there should be a message telling reason for RAM inference failure.
I can tell that initialization of inferred RAM works for me with init functions.
Are you using MAX10 without RAM initialization feature?
obruendl
@FvM
I couldn't find any message about failed RAM inference in the report. You can find the report here, so you can check yourself.
https://drive.google.com/file/d/1UBp4T_LOryi9wlOndzk2sym02u92Ym-4/view?usp=drive_link
ShengN_Intel
May I know does the code being attached?
Sheng
obruendl
@ShengN_Intel
I attached a ZIP to the forum post - seems like it was dropped silently...
You can get the ZIP with the code from my google-drive: https://drive.google.com/file/d/1RN4Dxybv4DdVjD169ncRZsm_r1JkagAj/view?usp=drive_link
obruendl
I ran some more tests of the same code. It seems like Quartus is pretty much alone in terms of struggling with my code.
Efinity (Efinix), Gowin EDA (Gowin), Vivado (AMD) and Libero (Microchip) all handle the code well.
FvM
I can't recognize/reproduce the issue with given information:
- According to report, block memory is inferred
- Top level entity RamWrp.vhd is missing, thus we can't reproduce actual design implementation with all parameters
Preferably we'll have a .qar project archive available
Frank
obruendl
The code describes a simple-dual-port memory of 4kbit in size. Yes, some RAM is inferred but in addition to that RAM I see > 7000 registers which I would not be expected. The code really only describes a RAM.
In the meantime a contributor of Open Logic identified that RAM inference works correctly when commenting out the Byte-Enable Logic. See GitHub issue for details: https://github.com/open-logic/open-logic/issues/122
The strange thing is that the configuration of the RAM I use here does not even make use of Byte Enables. Generics are set to not use Byte-Enables - so the logic that breaks inference is unused.
I agree that the files I provided are inconsistent because I tried out a few things. I now archived the project in Quartus (QAR) in two ways:
- The failing version (including byte-enable logic): https://drive.google.com/file/d/13sTr6c7nqkbVoqz2a4C808FaXzsyirUN/view?usp=drive_link
- A version with byte-enable logic commented (which does infer RAMs correctly): https://drive.google.com/file/d/10Wbemcy09Xk6Y99eESxcZIhgwJy5aTuf/view?usp=drive_link
obruendl
I have even more interesting news. I fixed my memory to 16 bits and played with the exact formulations in VHDL.
Below code fails to infer RAM:
for byte in 0 to 1 loop
    if Wr_Be(byte) = '1' then
        Mem_v(to_integer(unsigned(Wr_Addr)))(byte * 8 + 7 downto byte *  := Wr_Data(byte * 8 + 7 downto byte * 8);
    end if;
end loop;
If I just unroll the loop, RAM is inferred correctly:
if Wr_Be(0) = '1' then
    Mem_v(to_integer(unsigned(Wr_Addr)))(7 downto 0) := Wr_Data(7 downto 0);
end if;
if Wr_Be(1) = '1' then
    Mem_v(to_integer(unsigned(Wr_Addr)))(15 downto  := Wr_Data(15 downto 8);
end if;
I feel like formulating the very same thing in a loop or unrolled should lead to the same results and if it does not, I'd call this a bug.
Unfortunately I still didn't find a language construct to cleanly work around this bug for parametrizable code - without understanding the root-cause making Quartus to behave different for the two snippets above it is difficult to find one because this (to my understanding) is not a logical issue.
Please provide suggestions how this issue can be worked around. Alternatively I could accept a confirmation of this being a bug that will be fixed in the next release of Quartus. If I know its getting fixed it'd be fine for me to just document that RAM inference for Altera works correctly starting from 25.1.
ShengN_Intel
It's not a bug. Just the pro and standard version support different format for RAM byteenable.
The format provided by you is only supported in pro version check this link https://www.intel.com/content/www/us/en/docs/programmable/683082/24-2/ram-with-byte-enable-signals.html
For Standard version link https://www.intel.com/content/www/us/en/docs/programmable/683323/18-1/ram-with-byte-enable-signals.html, have to change to something like below:
Mem_v(to_integer(unsigned(Wr_Addr)))(7 downto 0) := unsigned(Wr_Data(7 downto 0));
end if;
Mem_v(to_integer(unsigned(Wr_Addr)))(15 downto := unsigned(Wr_Data(15 downto 8));
end if;
Then the ram will be inferred check attached screenshot.
obruendl
I am - let's say surprised - by the fact that such slight details like supporting loops for BE in memory inference differing between the paid and the free version of Quartus. It's impossible for users to keep track of this...
However, technically you answered the question why inference does not work. The question now is how I shall proceed from here.
I am maintaining an Open Source FPGA Standard library - which according to GitHub stars belongs to the most popular ones around (see https://github.com/open-logic/open-logic). Of course I will document that RAM inference might not work for Quartus Standard. However, I would want to verify it to work with Quartus Pro. Would Altera be open to donate a Pro License to the Open Logic project for this purpose?
IMO this would be in the mutual interest of both sides: I'd like to verify RAM inference for Altera devices at least with Quartus Pro. If I do so, users probably are motivated to buy Quartus Pro which is in the interest of Altera.
BTW: I ran into other errors with True-Dual-Port RAM inference - but I guess I should try this one with Quartus Pro as well.
ShengN_Intel
You may try with the pro version. The pro version has 30-day evaluation license.
Btw, I had done the testing in pro version and it works well.
Sheng
FvM
despite of license requirements, Pro version is not a solution because you don't have a choice to use either Std/Lite or Pro version for a specific FPGA series.
Although I'm frequently using RAM inference in my code, with both Quartus versions, I must confess that I'm surprised about the observed behaviour. Curiously Quartus infers RAM for 1 bit and registers for the other 15 bits of 16 Bit word in the present example. In fact the problem doesn't occur with Altera suggested RAM coding style.
FvM
Hi ShengN,
thanks for the links. Apparently I didn't yet infer Byte Enable with Quartus Standard. It's strange though that generated byte enable doesn't work, even with true generate for statement. But we should take it as is.
obruendl
I have to be honest - I disagree with the conclusion "we should take it as it is".
The situation as I understood is:
- No tool supports all FPGA series (some are exclusively for lite, some exclusively for pro)
- The two tool versions have different coding requirements for inference (its not "pro just understands more")
If this is true, this would mean no-one can write code that compiles for all Altera devices. Which is rather catastrophic - how would people provide IP for your devices. My library is open-source - but there also is the whole business of paid IP. And all IP actually acts as enabler for Altera devices being used in applications. Why would Altera put stones into the way of people producing IP for their devices? And why would Altera want to put itself in a far much less customer friendly position than its competitors that provide the exact same synthesis engine in paid and free versions (and just differ in terms of IP, device support and the like)?
My vote here would rather be pushing towards fixing the situation.
Way Forward
I still would hope that I can at least find a way to write modular inference based code at least with the Pro version (the restrictions of Standard make this impossible). Using a eval version is not an option - I am aiming for long term maintenance. Please check if there is a way to get a free Pro license for Open Logic (an open source project acting as enabler for customers using your devices).
I'd prefer documenting that with Pro version (even if this restricts the target devices) everything works fine over stating that there are severe limitations for Altera. But finally the choice to provide a license or not is Alteras.
ShengN_Intel
I had open an enhancement request to internal team for Standard version.
For license, you can generate the evaluation license from SSLC https://licensing.intel.com/psg/s/?language=en_US, usually evaluation license is used to evaluate the Quartus Tool.
Sheng
