17258 Discussions
RTL Module Packaged into OpenCL Library
Does anyone have integrated a RTL Module (VHDL/Verilog) in a OpenCL Kernel as a helper function ?I don't clearly about Using an OpenCL Library that Works with External Memory
(Example 2)?I don't understand the way of performing the working with External Memory.What is the meaning of helper function?
