17256 Discussions
Why does one single load/store consume much RAMs?
when I design OpenCL and run aocl, it reports that one single load consume 13 RAMs and one single store consume 16 RAMs.
e.g
__kernel void top_kernel(__global restrict volatile int *a, __global restrict volatile int *b, __global restrict volatile int *c) {
int i;
for (i = 0; i < 10000; ++i)
c = a + b[i]; // it will consume 13x2 + 16 RAMs
The RAMs are used as FIFO buffers to minimize the negative effect of stalls caused by off-chip memory accesses which can have variable latency. There are also some extra RAMs used per off-chip memory access as a private cache, but since your kernel arguments have been defined as volatile, that cache will not be used.
--- Quote Start ---
--- Quote End ---
Thanks for your reply.
Can we disable or decrease the RAM usage?
Other than disabling the cache using volatile, there is nothing else that can be done. Is there a specific reason you want to do this? Removing those FIFOs will have a very large negative impact on performance.
--- Quote Start ---
--- Quote End ---
I also saw that using volatile can disable the cache.
I want to apply coarse grained parallel on external memory access, e.g.
# pragma unroll
for (i = 0; i < 64; ++i)
for (j = 0; j < 1000; ++j)
... = a[i * 1000 + j];
It will consume a lot of RAMs (64 * 16 RAMs) while total of RAMs is about 2700 RAMs in arria10.
After that, we have little optimization space because of lack of RAMs.
Considering the very low memory bandwidth on current FPGA boards and the very high overhead of contention for off-chip memory accesses, you should actually avoid having parallel memory accesses and instead, unroll your memory accesses in a way that they will be coalesced into bigger ones, to minimize the number of ports to external memory. These ports, as you have noticed, waste a lot of space on the FPGA.
In your code example, you are unrolling the i loop, while the memory accesses are not contiguous over the i dimension and hence, you get 64 memory ports. This, apart from very high area usage, will lower your memory bandwidth to near-zero due to constant contention between all those ports. However, if you partially unroll the j loop 64 times, since the accesses are contiguous, you will get a few large coalesced ports with very low area overhead, and you will get very close to theoretical memory bandwidth.
--- Quote Start ---
--- Quote End ---
I totally agree with your suggestion. I have tried and it works.
