Hello everybody,
I'm a newbie on VHDL programming, but for a course at university we have to deal with the DE1-SoC and the THDB-ADA Board. I want to read out the values of the ADC and display them in the signal analyzer in Quartus. So this is my source code (.vhdl): library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity adc_test is
port(
adc_cs_n: in std_logic; --internal adc
adc_din: out std_logic;
adc_dout: in std_logic;
adc_sclk: out std_logic;
clock_50: in std_logic; --clocks
clock2_50: in std_logic;
clock3_50: in std_logic;
clock4_50: in std_logic;
dram_addr: out std_logic_vector(12 downto 0); --sdram
dram_ba: out std_logic_vector(1 downto 0);
dram_cas_n: out std_logic;
dram_cke: out std_logic;
dram_clk: out std_logic;
dram_cs_n: out std_logic;
dram_dq: inout std_logic_vector(15 downto 0);
dram_ldqm: out std_logic;
dram_ras_n:out std_logic;
dram_udqm: out std_logic;
dram_we_n: out std_logic;
adc_clk_a: out std_logic; --gpio
adc_clk_b: out std_logic;
adc_da: in std_logic_vector(13 downto 0);
adc_db: in std_logic_vector(13 downto 0);
adc_oeb_a:out std_logic;
adc_oeb_b:out std_logic;
adc_otr_a:in std_logic;
adc_otr_b:in std_logic;
dac_clk_a: out std_logic;
dac_clk_b: out std_logic;
dac_da: in std_logic_vector(13 downto 0);
dac_db: in std_logic_vector(13 downto 0);
dac_mode: out std_logic;
dac_wrt_a: out std_logic;
dac_wrt_b: out std_logic;
osc_sma_adc4: in std_logic;
power_on: out std_logic;
sma_dac4: in std_logic
end adc_test;
architecture arch_adc of adc_test is
signal clk : std_logic;
begin
process(clock_50)
begin
clk <= clock_50;
end process;
end arch_adc; Complilation succeeded but when I start the signal analyzer it displays "waiting for clock". Do you have some ideas what I forgot to include? Do I have to include an pll? Thank you for your help. Christoph :o
can you post your SignalTap setup window?- Mark as New
--- Quote Start --- Hi, can you post your SignalTap setup window? --- Quote End --- hi vlrean, I solved this problem already, i forgot to map the clock_50 on the right hand side of the window (signal configuration). But I didn't see any signal input. Best regards, Chris
Are ADC_CLK_A and ADC_CLK_B clocks to the ADC? If so, you don't appear to be driving them (of course, it's a bad idea to clock an ADC from an FPGA output). Are ADC_OEB_A and ADC_OEB_B enables for the ADC? Make sure the ADC is not powered down. You don't say how you are triggering SignalTap. Some boards have lots of jumpers that must be set.
--- Quote Start --- Are ADC_CLK_A and ADC_CLK_B clocks to the ADC? If so, you don't appear to be driving them (of course, it's a bad idea to clock an ADC from an FPGA output). Are ADC_OEB_A and ADC_OEB_B enables for the ADC? Make sure the ADC is not powered down. You don't say how you are triggering SignalTap. Some boards have lots of jumpers that must be set. --- Quote End --- hi corestar, thank you for your suggestion, but I solved the problem. my updated code is: library ieee; use ieee.std_logic_1164.ALL; use ieee.std_logic_unsigned.all; entity ADC_test is port( ADC_CS_N: in std_logic; --internal ADC ADC_DIN: out std_logic; ADC_DOUT: in std_logic; ADC_SCLK: out std_logic; CLOCK_50: in std_logic; --clocks CLOCK2_50: in std_logic; CLOCK3_50: in std_logic; CLOCK4_50: in std_logic; DRAM_ADDR: out std_logic_vector(12 downto 0); --SDRAM DRAM_BA: out std_logic_vector(1 downto 0); DRAM_CAS_N: out std_logic; DRAM_CKE: out std_logic; DRAM_CLK: out std_logic; DRAM_CS_N: out std_logic; DRAM_DQ: inout std_logic_vector(15 downto 0); DRAM_LDQM: out std_logic; DRAM_RAS_N:out std_logic; DRAM_UDQM: out std_logic; DRAM_WE_N: out std_logic; ADC_CLK_A: out std_logic; --GPIO ADC_CLK_B: out std_logic; ADC_DA: in std_logic_vector(13 downto 0); ADC_DB: in std_logic_vector(13 downto 0); ADC_OEB_A:out std_logic; ADC_OEB_B:out std_logic; ADC_OTR_A:in std_logic; ADC_OTR_B:in std_logic; DAC_CLK_A: out std_logic; DAC_CLK_B: out std_logic; DAC_DA: in std_logic_vector(13 downto 0); DAC_DB: in std_logic_vector(13 downto 0); DAC_MODE: out std_logic; DAC_WRT_A: out std_logic; DAC_WRT_B: out std_logic; OSC_SMA_ADC4: in std_logic; POWER_ON: out std_logic; SMA_DAC4: in std_logic ); end ADC_test; architecture arch_adc of ADC_test is begin DAC_MODE <= '0'; ADC_CLK_B <= CLOCK_50; ADC_CLK_A <= CLOCK_50; ADC_OEB_A <= '0'; ADC_OEB_B <= '0'; POWER_ON <= '1'; end arch_adc; My current question is how to integrate the PLL from the Megawizard of the Quartus software. Best regards, Chris
