17268 Discussions
Read responses on not reaching PIO interface through mm_interconnect
SivaKona
Quartus Version : 22.2.0.94
A "Multi Channel DMA Intel® FPGA IP for PCI Express" IP is integrated with AXI4 DUT and On Chip Memory.
Data Responses for BAR2 MMIO read requests are not reaching PIO interface.
The attached "NoReadResponseAtPIO.png" shows
=> a valid Read response is present on DUT AXI interface.
=> rx_pio_waitrequest_i goes low
=> rx_pio_readdatavalid_i does not toggle.
This results in a hang in mm_interconnect. Subsequent read/writes initiated on rx_pio does not pass through mm_interconnect.
How can we overcome this issue?
Siva Kona
Wincent_Altera
The PIO is always mapped to BAR2, see 3.1.4. Avalon-MM PIO Master:
https://www.intel.com/content/www/us/en/programmable/documentation/xzr1589413426034.html#pis1593481713202
See also 4.1.1 which mentions the addressing:
https://www.intel.com/content/www/us/en/programmable/documentation/xzr1589413426034.html#yxs1589416421751
BAR0 is always used for the Control Register Block (CSR), see 3.1.9. Control Registers
https://www.intel.com/content/www/us/en/programmable/documentation/xzr1589413426034.html#obt1591741708879
The Bursting Avalon-MM Master (BAM) can be mapped to any BAR other than 0, see 3.2. Bursting Avalon-MM Master (BAM)
https://www.intel.com/content/www/us/en/programmable/documentation/xzr1589413426034.html#jtr1620084136317
8.2.7 API List, table 97 to 100 detail the PIO API format:
https://www.intel.com/content/www/us/en/programmable/documentation/xzr1589413426034.html#wqx1626225113388
Our Example Design can be generate to include a PIO Master on BAR2, as a starting point you may want to generate and refer to that:
https://www.intel.com/content/www/us/en/programmable/documentation/nki1590181067003.html#bdn1621555193678
Wincent_Intel
SivaKona
Hi Wincent_Intel, Good Morning!
We have generated an SOF with Quartus Version 22.3 and observed the same behavior to persist.
The issue is NOT resolved yet. Request you for further inputs.
Is this behavior due to issues in mm_interconnect or PCIe Endpoint?
Siva Kona
Wincent_Altera
Will close here as the communication move to private.
