17268 Discussions
Recompilation after modifications in signaltap
Hello everybody,
I'm facing a long compilation times issue in Quartus everytime I make any modifications in the signal set (i have a Nios II + custom coprocessor system which takes more than 1 hour to compile).
Do you know if there's a way to avoid recompiling the whole system? If I try design partitions I somehow get lots of error about what i think are some signal encapsulation requirements.
Thanks a lot
Hi, when you use SignalTap, you have a switch named "Allow all changes / allow triggers changes only" (something similar) above the data settings in order to not recompile the whole
BUT you can't change the signal set anymore except triggers, transitional save...
Put a wide set of signal, after you will opt what you want.
In Quartus 12.0sp1, I face to a little problem : SignalTap sometimes does not recognize my trigger conditions, I have to save and reload.
Well, I don't have much free BRAM on my device so I can't have such a wide set of signals. I don't think I can ignore some signal logging afterwards either, is that right?
Since SignalTap has to re-routing the FPGA, It is hard to compile partitions only.
Since Signaltap needs a compile, so as the FPGA to be configured, ignoring signals afterwards will not optimize the FPGA ressources.
For a work around, as i said, you can set a wide range of significant signals,
You can change your signaltap clock to a slower "clock"
You can use transitional storage
