Hello Frinds,
I m using Cyclon Device for my Project with quartus II-9.1. now in my system i need one pll for altera sdram controller to provide clock with phase shift of -3.51 ns (as par datasheet of sdram -3.35 ns). if i m using above PLL setting inside SOPC then my whol system working as par needed without any error. But if i m using this same PLL in BDF level (outside SOPC Builder) then SDRAM hang during operation. When i m changing PLL phase shift at BDF level (replace -3.35 ns with -3.90 to above) then system working as par needed without erros. So can anyone tell me y same PLL phase shift not working in BDF level (means in SOPC phase shift -3.35 ns and need to change in BDF level for proper working)??? what is possible reason behind this type of problem?? Regards: DGLink Copied
