17255 Discussions
Regenerate .ip files automatically
RPett4
In our version control tool, only the *.ip files were checked in. When I try to compile the design in Quartus, it complains that "The synthesis RTL for *.ip has not been generated. Generate the synthesis RTL from within Platform Designer." In Quartus, I can manually open each *.ip file in the "IP Parameter Editor" and click "Generate HDL..." and everything is fine.
Is there a way to automate this step? I would like to just click "Compile Design" and then have these "Generate HDL" commands happen automatically.
KennyTan_Altera
There is a option for you,
You can go to assignment -> settings -> IP settings. Check which setting you will need to turn on.
KennyTan_Altera
KennyTan_Altera
Any update?
RPett4
This is a pretty good solution, and it worked. Does this setting get saved into a project file? The reason I ask is that if I build on my own computer, it works fine since I have already changed the setting in my instance of Quartus Prime. But if someone else tried to compile the project on a different computer, my worry is that it would fail and it is possible that they would not know that this setting needs to be changed.
KennyTan_Altera
Yes, it should be. what you can do is archieve the project to *.qar files. Can unarchieve it to check the setting again.
If it does not save, let me know as it would be a bug.
KennyTan_Altera
Any further question?
