17255 Discussions
Register to remember Compiling day or time, version control
Hi
Currently, I am try to do version control.
I am wondering, is it have anyway to record when I did this compiling?
TINGMING
--- Quote Start ---
See http://www.altera.com/support/examples/tcl/tcl-date-time-stamp.html
--- Quote End ---
This tcl may be a quicker way of getting timestamp and writing it as constant into a package.
# open time stamp VHDL file set fp # get current date & time (yymmddhhmm) set str_ascii -format {%y%m%d%H%M}] # write to above VHDL file puts $fp "library IEEE;" puts $fp "use IEEE.std_logic_1164.all;" puts $fp "use IEEE.numeric_std.all;" puts $fp \n puts $fp "package Timestamp is" puts $fp " constant TIMESTAMP : std_logic_vector(31 downto 0) := std_logic_vector(TO_UNSIGNED($str_ascii, 32));" puts $fp "end package;" close $fp
Thanks cronus10 and kaz
Just share with people with TCL file for verilog version
# # # you must add the following line into your QSF file# # set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:./create_timestamp.tcl"# # # # open time stamp Verilog file set fp # get current date & time (yymmddhhmm) set str_ascii -format {%y%m%d%H%M}] set show_ascii -format {%Y %b %d %I:%M:%S %p}] # write to above VHDL file puts $fp "\/\/\tyou must add the following line into your QSF file" puts $fp "\/\/" puts $fp "\/\/\t\t set_global_assignment -name PRE_FLOW_SCRIPT_FILE \"quartus_sh\:\.\/create_timestamp.tcl\"" puts $fp "\/\/" puts $fp "\/\/\tCompiling Date: $show_ascii" puts $fp "module timestamp(dout);" puts $fp "\toutput wire \ dout = 32\'d$str_ascii;" puts $fp "endmodule" close $fp
