Relational operators
I don't understand why the following code doesn't work, can you enlighten me ?
freq_authorization : process(clk) begin if rising_edge(clk) then if ((unsigned(freq) >= "00001100" ) and (unsigned(freq) <= "00111101" )) then --compare if freq entry is between 12 and 59 allowed_freq <= '1'; else allowed_freq <= '0'; end if; end if; end process freq_authorization;
If it can help, modelsim is returning# ** Warning: NUMERIC_STD.">=": metavalue detected, returning FALSE when I run.
Thanks for your help.
EDIT : freq is in std_logic_vector(7 downto 0);
freq has not been initialized
What do you mean ? Freq is my entry port
--- Quote Start ---
--- Quote End ---
Yes, have you set the value for Freq in your testbench? if it contains 'U' (uninitialised) or 'X' (unknown) then you get the warning you have.
Thanks, your advices led me to solve my problem.
