17261 Discussions
Replacing a process with 1-port RAM
i have process I need to now implement as ROM.
process (count, outi, run) --converter begin if (run = '1') then -- run is a physical switch case count is -- count is the current value of a 2 bit counter when "00" => outi <= "1000"; when "01" => outi <= "0100"; when "10" => outi <= "0001"; when "11" => outi <= "0010"; when others => outi <= "0000"; end case; end if; end process;
The output outi is assigned to LEDS outside the process.
I have created 1 port ram and created a mif file that looks like this
Addr
+0
+1
+2
+3
ASCII
1000
0100
0001
0010
But I'm not sure what exactly I need to do now.
I'm very to new to VHDL and FPGAs in general.
I attached the project
