17258 Discussions
Replacing a process with 1-port RAM
i have process I need to now implement as ROM.
process (count, outi, run) --converter begin if (run = '1') then -- run is a physical switch case count is -- count is the current value of a 2 bit counter when "00" => outi <= "1000"; when "01" => outi <= "0100"; when "10" => outi <= "0001"; when "11" => outi <= "0010"; when others => outi <= "0000"; end case; end if; end process;
The output outi is assigned to LEDS outside the process.
I have created 1 port ram and created a mif file that looks like this
Addr
+0
+1
+2
+3
ASCII
1000
0100
0001
0010
But I'm not sure what exactly I need to do now.
I'm very to new to VHDL and FPGAs in general.
The question is, what is wrong with the current decoder?
What code have you written already, and what are the end goals? For a ROM you have a few options:
1. Use a wizard generated ROM, initialise with a .mif file
2. Define a constant and then follow the ROM template (available in the HDL coding guidelines of the Quartus Manual - and/or you can generate the template in Quartus)
3. Keep with the decoder structure, but add a clock.
What do you need us to help with?
If indeed you want to use the 1-port RAM as a ROM, you'd need to remove your decoder logic (the case statement) and instantiate the RAM in your design, attaching count to the address input of the RAM and outi to the output of the RAM.
--- Quote Start ---
--- Quote End ---
You can infer a ROM from decoder logic, if it is clocked.
See "inferring ROM" from the Quartus HDL coding guidelines
--- Quote Start ---
--- Quote End ---
sorry for really late reply. i forgot oops.
I have actually done that with block diagrams but I want to do it using only vhdl now I just don't know how I'd go about doing that
--- Quote Start ---
--- Quote End ---
Have you read the quartus handbook, the section on HDL coding guidelines?
https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-handbook.pdf
Specifically, Page 12-27 - Inferring ROM Functions from HDL Code
I read part of it a while ago, guess i forgot about.
I found this --http://www.alteraforum.com/forum/showthread.php?t=5958--
all I actually needed to do was use component instantiation and port map to connect the ROM to the main file.
Thank you for your help.
I'm not sure if this is allowed but I have a problem with simulation.
https://www.alteraforum.com/forum/attachment.php?attachmentid=13657
The overall output of the entire program works but I want to see the internals.
I get Us when I run a simulation for example I'm expecting the same output for "step" as "ROM:U1|address"
U1 is a 1-port RAM that I instantiated and implemented as "ROM".
Without seeing the code, it is impossible to say what is wrong.
--- Quote Start ---
--- Quote End ---
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity school is Port ( CLOCK_50 : in std_logic; run : in std_logic; dir : in std_logic; step : out std_logic_vector (1 downto 0); led : out std_logic_vector(3 downto 0); slow_fast : in std_logic ); end school; architecture Behavioral of school is signal divider : std_logic_vector (22 downto 0); signal count : std_logic_vector (1 downto 0); signal current_clk : std_logic; component ROM IS PORT ( address : IN STD_LOGIC_VECTOR (1 DOWNTO 0); clock : IN STD_LOGIC := '1'; data : IN STD_LOGIC_VECTOR (3 DOWNTO 0); wren : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (3 DOWNTO 0) ); END component; begin U1 : ROM PORT MAP ( clock => current_clk, address => count, q => led, wren => '0', data => "0000" ); process (divider, CLOCK_50) begin if rising_edge(CLOCK_50) then divider <= divider + 1; end if; end process; process (run, divider, current_clk, dir, count, slow_fast ) begin if slow_fast = '1' then current_clk <= divider(0); else current_clk <= divider(1); end if; if (rising_edge(current_clk) and run = '1') then -- case dir is when '0' => count <= count + 1; when '1' => count <= count - 1; when others => count <= count + 1; end case; end if; end process; step <= count; end Behavioral;
Count doesnt have an initial value, or a reset value, hence it will initialise (in simulation) to 'U'
You also have other issues:
1. You should create logic divided clocks- they are prone to timing issues on hardware
2/ do not use "and" with the clock
3. its better to separate asynchronous and synchronous logic into different processes.
--- Quote Start ---
--- Quote End ---
I changed count to now be
signal count : std_logic_vector (1 downto 0) :="00";
1. I'm sure what logic divided clock means.
2. I changed it and used if conditions instead.
3. I've done that also
The output is still U for all of the U1 signals after running sim and count still initialises as U
Your "current_clk" is a logic generated clock, because you used logic to generate a clock
Much better to use clock enables instead.
I made two process for different frequencies now the output looks time shifted but I don't really care about that for no. I still can't see any of U1's signals, they're all still U or UU or UUUU. is it that its just not possible or something?
Did you set and initial value for count? or reset it?
yeah signal count : std_logic_vector (1 downto 0) :="00";
And where is the testbench code? have you tried testing in modelsim?
--- Quote Start ---
--- Quote End ---
I just made this
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity test is end test; architecture Behavioral of test is component tet is Port ( CLOCK_50 : in std_logic; run : in std_logic; dir : in std_logic; step : out std_logic_vector (1 downto 0); led : out std_logic_vector(3 downto 0):="1000"; slow_fast : in std_logic ); end component; signal run_a : std_logic := '1'; signal clk_a : std_logic := '0'; signal dir_a : std_logic := '1'; signal slow_a : std_logic := '0'; constant clkp : time := 20ps; signal step_a : std_logic_vector (1 downto 0); signal led_a : std_logic_vector (3 downto 0); begin A1 : tet port map (clk_a, run_a, dir_a, step_a, led_a, slow_a ); clk_proc : process begin clk_a <= '0'; wait for clkp/2; clk_a <= '1'; wait for clkp/2; end process; stim_proc: process begin wait for 20 ps; run_a <='1'; dir_a <= '1'; slow_a <= '0'; wait for 300 ps; run_a <='0'; wait for 300 ps; run_a <= '1'; dir_a <= '0'; wait for 300 ps; slow_a <= '1'; wait for 300 ps; end process; end Behavioral;
step and led show up as "UU" and "UUUU" but the signal assignments work.
But if i use the university program simulation, the main program works fine (apart from the Us I get for the ROM)
Did you assign any values to the rom? without specifying the contents, it will simulate with all U
--- Quote Start ---
--- Quote End ---
yeah i did. It was in my first post
You first post shows code that would infer a rom from code. The later code shows a component called "rom" with no port called "count"
Please post ALL of your code. Why not post the project?
