17268 Discussions
Reversing bits in a bus in verilog...
I was wondering about the easy way to reverse bits in a bus in Verilog. Here is the code I wrote:
if (rev) begin
out[29:0] <= inp[0:29]; // Reverse video data buss bit order
end else begin // !rev
out[29:0] <= inp[29:0]; // Normal video data buss bit order
end
The second line came up with a compile error: Part select direction is opposite...
Is there a quick way to do this without writing out each wire?
In VHDL a for loop is necessary for the bit reversal, I think, it's also the case in Verilog.
--- Quote Start ---
--- Quote End ---
Are you saying to place :
for ( n=0 ; n < 30 ; n=n+1 ) begin
out[n] <= inp[29-n]; // Reverse video data buss bit order
end
in place of the -> out[29:0] <= inp[0:29];
I'm assuming my Verilog use of a 'for loop' here is correct....
Yes, it looks OK.
welll.. there's a bug in Quartus ...
if you have:
wire [9:0] a;
wire [0:-9] b;
then:
assign a=b;
causes a flip.
If you can use SystemVerilog, its simple to use the streaming operator
out = {<<{inp}}; // right to left streaming
--- Quote Start ---
--- Quote End ---
Since this post is under "Quartus II," it's worth noting that Quartus does not support the streaming operator. It is still listed as "unsupported" in Q12.0:
http://quartushelp.altera.com/current/mergedprojects/hdl/vlog/vlog_list_sys_vlog.htm
(See section 11)
I tried it just for kicks and got a syntax error. ModelSim recognized it, though.
