In my VHDL application I have some registers which are readable via SPI by a CPU. I would like to have one of the registers report the current source code revision.
I am using Subversion + TortoiseSVN for revision control on my Quartus project. Subversion comes with a utility which can put the current source revision into your source code, so that every time you build, the version number can automatically be updated in the logic itself. So my plan is is have a batch file which calls SubWCRev.exe. This takes a template file, substitutes the variable $WCREV$ with the subversion revision number and writes the output to dualPortRegs.mif. This way, my FPGA version register will always refer to the correct source version. However, I would really like this batch file to be executed whenever I direct Quartus to compile. Is there a way to tell Quartus to run a batch file before compiling my project? This way I can't ever forget to update the version number; It will happen automatically. Thanks, -KevinLink Copied
you might look into a command line flow. you could make just a single file, compile.bat. this would call your .exe, then run quartus_sh --flow compile <proj_name>.
A batch file is probably easiest, since it's just the two lines mentioned by thepancake. Note that you can have Quartus reun a pre-flow .tcl script. Look at:
http://www.altera.com/support/examples/tcl/tcl-version-number.html?gsa_pos=2&wt.oss_r=1&wt.oss=timestamp THe key is adding the following line to your .qsf: set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:<script name> That way you can use the GUI for compiles and it will still work. Of course, you then need to figure out how to get your .tcl file to run the executable, which I'm not sure how to do(and why the first method is easier...)- Mark as New
--- Quote Start --- Of course, you then need to figure out how to get your .tcl file to run the executable, which I'm not sure how to do(and why the first method is easier...) --- Quote End --- this is also a nice solution. in your tcl try: exec <script.bat>
Woohoo!
Exactly what I needed. Thanks very much! -Kevin- Mark as New
You can generate Timestamp in QSYS custom IP, just add single line code# source "data_time.tcl"# in your .tcl file.
# TCL File Generated by Component Editor 16.1# Mon Dec 19 19:08:17 JST 2016# DO NOT MODIFY
# # spi_ctrl "SPI Slave Controllor" v1.3# Ben.C.Kevin 2016.12.19.19:08:17# #
# # request TCL package from ACDS 16.1#
package require -exact qsys 16.1
# # module spi_ctrl#
set_module_property DESCRIPTION ""
set_module_property NAME spi_ctrl
set_module_property VERSION 1.3
set_module_property INTERNAL false
set_module_property OPAQUE_ADDRESS_MAP true
set_module_property GROUP SPI
set_module_property AUTHOR Ben.C.Kevin
set_module_property DISPLAY_NAME "SPI Slave Controllor"
set_module_property INSTANTIATE_IN_SYSTEM_MODULE true
set_module_property EDITABLE true
set_module_property REPORT_TO_TALKBACK false
set_module_property ALLOW_GREYBOX_GENERATION false
set_module_property REPORT_HIERARCHY false
# # file sets#
add_fileset QUARTUS_SYNTH QUARTUS_SYNTH "" ""
set_fileset_property QUARTUS_SYNTH TOP_LEVEL spi_ctrl
set_fileset_property QUARTUS_SYNTH ENABLE_RELATIVE_INCLUDE_PATHS false
set_fileset_property QUARTUS_SYNTH ENABLE_FILE_OVERWRITE_MODE false
add_fileset_file spi_ctrl.vhd VHDL PATH spi_ctrl.vhd TOP_LEVEL_FILE
add_fileset_file spi_slave.vhd VHDL PATH spi_slave.vhd
add_fileset_file true_dual_port_ram_single_clock.vhd VHDL PATH true_dual_port_ram_single_clock.vhd
add_fileset_file spi_ver_reg.vhd VHDL PATH spi_ver_reg.vhd
add_fileset_file data_time.tcl OTHER PATH data_time.tcl CONTAINS_INLINE_CONFIGURATION
# # parameters#
add_parameter N POSITIVE 8 ""
set_parameter_property N DEFAULT_VALUE 8
set_parameter_property N DISPLAY_NAME N
set_parameter_property N TYPE POSITIVE
set_parameter_property N UNITS None
set_parameter_property N ALLOWED_RANGES 1:2147483647
set_parameter_property N DESCRIPTION ""
set_parameter_property N HDL_PARAMETER true
add_parameter CPOL STD_LOGIC 0
set_parameter_property CPOL DEFAULT_VALUE 0
set_parameter_property CPOL DISPLAY_NAME CPOL
set_parameter_property CPOL TYPE STD_LOGIC
set_parameter_property CPOL UNITS None
set_parameter_property CPOL ALLOWED_RANGES 0:1
set_parameter_property CPOL HDL_PARAMETER true
add_parameter CPHA STD_LOGIC 0
set_parameter_property CPHA DEFAULT_VALUE 0
set_parameter_property CPHA DISPLAY_NAME CPHA
set_parameter_property CPHA TYPE STD_LOGIC
set_parameter_property CPHA UNITS None
set_parameter_property CPHA ALLOWED_RANGES 0:1
set_parameter_property CPHA HDL_PARAMETER true
add_parameter PREFETCH POSITIVE 3
set_parameter_property PREFETCH DEFAULT_VALUE 3
set_parameter_property PREFETCH DISPLAY_NAME PREFETCH
set_parameter_property PREFETCH TYPE POSITIVE
set_parameter_property PREFETCH UNITS None
set_parameter_property PREFETCH ALLOWED_RANGES 1:8
set_parameter_property PREFETCH HDL_PARAMETER true
add_parameter BUFF_ADDR_WIDTH POSITIVE 10
set_parameter_property BUFF_ADDR_WIDTH DEFAULT_VALUE 10
set_parameter_property BUFF_ADDR_WIDTH DISPLAY_NAME PAGE_BUF_SIZE
set_parameter_property BUFF_ADDR_WIDTH TYPE POSITIVE
set_parameter_property BUFF_ADDR_WIDTH UNITS None
set_parameter_property BUFF_ADDR_WIDTH ALLOWED_RANGES 1:15
set_parameter_property BUFF_ADDR_WIDTH HDL_PARAMETER true
set_parameter_property BUFF_ADDR_WIDTH DESCRIPTION "2's power 14 is 64KByte"
# # display items#
# # connection point reset_sink#
add_interface reset_sink reset end
set_interface_property reset_sink associatedClock clock_sink
set_interface_property reset_sink synchronousEdges DEASSERT
set_interface_property reset_sink ENABLED true
set_interface_property reset_sink EXPORT_OF ""
set_interface_property reset_sink PORT_NAME_MAP ""
set_interface_property reset_sink CMSIS_SVD_VARIABLES ""
set_interface_property reset_sink SVD_ADDRESS_GROUP ""
add_interface_port reset_sink reset_n_i reset_n Input 1
# # connection point clock_sink#
add_interface clock_sink clock end
set_interface_property clock_sink clockRate 0
set_interface_property clock_sink ENABLED true
set_interface_property clock_sink EXPORT_OF ""
set_interface_property clock_sink PORT_NAME_MAP ""
set_interface_property clock_sink CMSIS_SVD_VARIABLES ""
set_interface_property clock_sink SVD_ADDRESS_GROUP ""
add_interface_port clock_sink clk_i clk Input 1
# # connection point conduit_end#
add_interface conduit_end conduit end
set_interface_property conduit_end associatedClock clock_sink
set_interface_property conduit_end associatedReset ""
set_interface_property conduit_end ENABLED true
set_interface_property conduit_end EXPORT_OF ""
set_interface_property conduit_end PORT_NAME_MAP ""
set_interface_property conduit_end CMSIS_SVD_VARIABLES ""
set_interface_property conduit_end SVD_ADDRESS_GROUP ""
add_interface_port conduit_end do_transfer_o debug_o Output 1
add_interface_port conduit_end spi_miso_o miso_o Output 1
add_interface_port conduit_end spi_mosi_i mosi_i Input 1
add_interface_port conduit_end spi_sck_i sck_i Input 1
add_interface_port conduit_end spi_ssel_i ss_n_i Input 1
# # connection point avalon_slave#
add_interface avalon_slave avalon end
set_interface_property avalon_slave addressUnits WORDS
set_interface_property avalon_slave associatedClock clock_sink
set_interface_property avalon_slave associatedReset reset_sink
set_interface_property avalon_slave bitsPerSymbol 8
set_interface_property avalon_slave burstOnBurstBoundariesOnly false
set_interface_property avalon_slave burstcountUnits WORDS
set_interface_property avalon_slave explicitAddressSpan 0
set_interface_property avalon_slave holdTime 0
set_interface_property avalon_slave linewrapBursts false
set_interface_property avalon_slave maximumPendingReadTransactions 0
set_interface_property avalon_slave maximumPendingWriteTransactions 0
set_interface_property avalon_slave readLatency 0
set_interface_property avalon_slave readWaitTime 1
set_interface_property avalon_slave setupTime 0
set_interface_property avalon_slave timingUnits Cycles
set_interface_property avalon_slave writeWaitTime 0
set_interface_property avalon_slave ENABLED true
set_interface_property avalon_slave EXPORT_OF ""
set_interface_property avalon_slave PORT_NAME_MAP ""
set_interface_property avalon_slave CMSIS_SVD_VARIABLES ""
set_interface_property avalon_slave SVD_ADDRESS_GROUP ""
add_interface_port avalon_slave avl_cs chipselect Input 1
add_interface_port avalon_slave avl_addr address Input 18
add_interface_port avalon_slave avl_d_i writedata Input 32
add_interface_port avalon_slave avl_we_i write Input 1
add_interface_port avalon_slave avl_wait_o waitrequest Output 1
add_interface_port avalon_slave avl_d_o readdata Output 32
set_interface_assignment avalon_slave embeddedsw.configuration.isFlash 0
set_interface_assignment avalon_slave embeddedsw.configuration.isMemoryDevice 0
set_interface_assignment avalon_slave embeddedsw.configuration.isNonVolatileStorage 0
set_interface_assignment avalon_slave embeddedsw.configuration.isPrintableDevice 0
# ================================================================================# # Build timestamp# # Create By :myfingerhurt# Create Date: 2014/12/18# # ================================================================================
set timestamp
puts " - Build timestamp ($timestamp 0x)"
set buildDate X""
set buildTime X""
puts "$buildDate $buildTime "
# Create a VHDL file for output
set outputFileName "spi_ver_reg.vhd"
set outputFile
# Output the Verilog source
puts $outputFile "--This file is Auto Generated BY datetime.tcl--"
puts $outputFile "--Create DateTime: $buildDate $buildTime"
puts $outputFile ""
puts $outputFile "LIBRARY ieee;\nUSE ieee.std_logic_1164.ALL;"
puts $outputFile "-------------------------------------------------------------------------------"
puts $outputFile "-- The package is here"
puts $outputFile "ENTITY spi_ver_reg IS"
puts $outputFile " PORT ("
puts $outputFile " oDate : OUT STD_LOGIC_VECTOR(31 downto 0);"
puts $outputFile " oTime : OUT STD_LOGIC_VECTOR(23 downto 0)"
puts $outputFile " );"
puts $outputFile "END spi_ver_reg;"
puts $outputFile "-- BODY"
puts $outputFile "ARCHITECTURE rtl OF spi_ver_reg IS"
puts $outputFile "BEGIN"
puts $outputFile " oDate <= $buildDate;"
puts $outputFile " oTime <= $buildTime;"
puts $outputFile "END rtl;"
puts $outputFile "------------------------END OF FILE--------------------------------------------"
close $outputFile
# Send confirmation message to the Messages window
puts stdout "Generated build identification VHDL module: /$outputFileName"
puts stdout "Date: $buildDate"
puts stdout "Time: $buildTime"
