17259 Discussions
Running a console executable from a tcl script
Hi there
I am attempting to call a console executable file from a tcl script that should run before every compile. Here are a few iterations that I have tried, but nothing seems to make the tcl script run the executable:
exec ConsoleApp.exe
qexec ConsoleApp.exe
exec BatchToRunConsoleApp.bat
qexec BatchToRunConsoleApp.bat
I am pretty desperate. I made the mistake of assuming that it would not be difficult to run an application from a tcl script and now I cannot seem to do it. Please help.
Stu84
this works here:
qexec ipconfig qexec quartus
also:
set cmd "qmegawiz -silent OPTIONAL_FILES=NONE ${file_name}" post_message "cmd: ${cmd}" if { } { post_message -type error "couldn't run $cmd" } else { post_message -type info }
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/tclscriptrefmnl.pdf
"qexec" is the command you should be using, and it works fine. You will need to supply more information about what doesn't work.
Do you need to specify the path to the executable, or make sure your PATH includes a .dll it depends on?
--- Quote Start ---
this works here:
also:
--- Quote End ---
Hi there DUESTERBERG
I tried your code snippets, and much like mine, they appear to do absolutely nothing. It says in themessage window that the tcl script executed successfully, but no windows consoles execute or appear. Is it poosible that there is something else that I am missing? Thank you for your help.
You'll get the results you describe if your executable doesn't produce any output to STDOUT.
Your script snippet works fine here.
Changing your cmd variable to instead use Windows cmd.exe to run the "set" command, you get your environment dumped into Quartus messages.
set cmd "cmd /c set" post_message "cmd: ${cmd}" if { } { post_message -type error "couldn't run $cmd" } else { post_message -type info "Command \"$cmd\" successful." post_message -type info }
If something basic as this doesn't work for you, not sure what next? Reinstall?
If this works, then there's a problem with your .exe, or there is a problem executing your .exe from a script like this.
--- Quote Start ---
--- Quote End ---
Thanks ted.
I appreciate all the help everyone. After playing around some more, I found my problem:
The tcl file runs in the project root directory and therefore saves the files there. When I run my app independently, the files are saved in the same directory as the app, hence the reason for my confusion. The code that uses "open" as described above does work, I still seem to be having some issues with qexec and exec, but this does not hinder my progress. Thanks again.
