- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi All,
How can I create the timing constraints (set_input/output_delay) for all ports (excepting clocks and reset ports)? Let's say the design has the following clocks: clk0, clk1, clk2 and following resets: rstn0, rstn1, rstn2 and hundreds of other ports. How can I write a script, which set input delays of 0ns for all input ports (excepting clk0, clk1, clk2, rstn0, rstn1, rstn2) and output delays of 0ns for all output ports? Thank you!- Balises:
- Intel® Quartus® Prime Software
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I don't quite understand what you want to accomplish here. Your input and output delays could be 0 for a *minimum* delay, but you also need a matching *maximum* delay. The range of delay is required to give the Fitter an idea of what it has to work with as to the placement of the input or output register.
set_input_delay -clock <virtual clock that drives upstream device> -max [get_ports in*] <max external delay based on tco of upstream device and board delays> set_input_delay -clock <virtual clock that drives upstream device> -min [get_ports in*] 0 set_output_delay -clock <virtual clock that drives downstream device> -max [get_ports out*] <max external delay based on tsu of downstream device and board delays> set_output_delay -clock <virtual clock that drives downstream device> -min [get_ports out*] 0- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Does the [get_ports out*] list all the output ports and [get_ports in*] list all the input ports?
How can I exclude certain ports from these listings? Is it possible to work with collections here? How to remove the input/output delay constraints from the certain ports? Thank you!- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
When I run the get_ports out* command from Quartus console, I'm receiving the following errors?
Error:ERROR: Quartus Prime Tcl command "get_ports" is only available for use in the following executables:
Error: quartus_fit
Error: quartus_sta
Error: while executing
Error: get_ports out*
Why? How to fix?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I used in* and out* as examples. You have to put in your own port names.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
this is exactly what I asked for :-) how to list ALL input ports without listing each port separately!
How can I make a collection (list) of ALL the input ports (something like 'create_collection all_inputs')?- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Just use all_inputs or all_outputs as your collection.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
running the all_inputs command gives the same result:
Error:ERROR: Quartus Prime Tcl command "all_inputs" is only available for use in the following executables:
Error: quartus_fit
Error: quartus_sta
Error:"all_inputs"
So, what's the solution?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Can you show your sdc file?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It's very simple - just several lines...
set_time_format -unit ns -decimal_places 3
create_clock -name {clk} -period 10.000 -waveform { 0.000 5.000 }
create_clock -name {fifo_rclk} -period 10.000 -waveform { 0.000 5.000 }
set_input_delay -clock { clk } 5
set_output_delay -clock { clk } 5
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Use something like:
set data_inputs [all_inputs] set data_inputs [remove_from_collection [all_inputs] clk] That will create a list without clock. If you want to remove something else, do another line: set data_inputs [remove_from_collection $data_inputs reset] Repeat as necessary. If you want to visually see what's in it, then do: query_collection -all -report $data_inputs Once correct, use in constraint: set_input_delay -clock clk -max 0.0 $data_inputs Then repeat for outputs- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
set_input_delay [get_ports * ] ... =====>the * wildcard covers all the input ports
remove_input_delay [get_ports clk] ===> will remove the input delay on the specified port Same thing for output delay. http://quartushelp.altera.com/15.0/mergedprojects/tafs/tafs/tcl_pkg_sdc_ver_1.5_cmd_remove_input_delay.htm- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- Just use all_inputs or all_outputs as your collection. --- Quote End --- OK, how could I list all the elements in these collections? What are the generated collections names?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- OK, how could I list all the elements in these collections? What are the generated collections names? --- Quote End --- I have a TCL script that has these lines in it to create files with the various 'collections' contents listed:
set chan
foreach_in_collection element {
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I tried to run the ferst example:
---------------------------------------------------------------------- set chan [open "TQ_all_clocks.rpt" "w"] foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]] } close $chan ---------------------------------------------------------------------- The 'all_clocks' command is not recognized (ran from the Tcl Console). I've got the following: ---------------------------------------------------------------------- Error:ERROR: Quartus Prime Tcl command "all_clocks" is only available for use in the following executables: Error: quartus_fit Error: quartus_sta Error: while executing Error:"all_clocks" Error: invoked from within Error:"foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]]}" ---------------------------------------------------------------------- So, what's the problem? How could be fixed? Thank you!- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- I tried to run the ferst example: ---------------------------------------------------------------------- set chan [open "TQ_all_clocks.rpt" "w"] foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]] } close $chan ---------------------------------------------------------------------- The 'all_clocks' command is not recognized (ran from the Tcl Console). I've got the following: ---------------------------------------------------------------------- Error:ERROR: Quartus Prime Tcl command "all_clocks" is only available for use in the following executables: Error: quartus_fit Error: quartus_sta Error: while executing Error:"all_clocks" Error: invoked from within Error:"foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]]}" ---------------------------------------------------------------------- So, what's the problem? How could be fixed? Thank you! --- Quote End --- Ok, so here is my complete example. Previously I just posted snippets but they need to be run in the correct context. I run this on the command line:
$(QUARTUS_BIN)/quartus_sta -t generate_timing.tcl $(DESIGN) 10
Where the contents of the file generate_timing.tcl is as follows: set projname
set numpaths
project_open $projname
create_timing_netlist
read_sdc
set_operating_conditions -model slow -grade c
update_timing_netlist
report_timing -setup -npaths $numpaths -detail path_only -file "TQ_setup_slow.rpt"
set_operating_conditions -model fast -grade c
report_timing -hold -npaths $numpaths -detail path_only -file "TQ_hold_fast.rpt"
report_exceptions -file "TQ_exceptions.rpt"
set chan
foreach_in_collection reg {
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
puts $chan ]
close $chan
set chan
foreach_in_collection cell {
puts $chan ]
close $chan
set chan
foreach_in_collection pin {
puts $chan ]
close $chan
set chan
foreach_in_collection net {
puts $chan ]
close $chan
set chan
foreach_in_collection port {
puts $chan ]
close $chan
set chan
foreach_in_collection clk {
puts $chan ]
close $chan
set chan
foreach_in_collection keeper {
puts $chan ]
close $chan
exit
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
where do you run the script? from outside of the Quartus? But ow can I run the same commands from the TCL Console (from inside of Quartus)?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- where do you run the script? from outside of the Quartus? But ow can I run the same commands from the TCL Console (from inside of Quartus)? --- Quote End --- As I indicated I run the commands from the command line using this command:
quartus_sta -t generate_timing.tcl MY_DESIGN 10
so the tcl script is fed to the Quartus Static Timing Analyzer (quartus_sta) application. So basically the tcl command script in the file is run on the TCL console within the quartus_sta application.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
If run from a script, then the following are necessary:
set projname [lindex $quartus(args) 0] set numpaths [lindex $quartus(args) 1] project_open $projname Most scripts I run I launch TimeQuest on the project and double-click on Update Timing Netlist, which does the following: create_timing_netlist read_sdc set_operating_conditions -model slow -grade c update_timing_netlist At that point I run a timing analysis script or whatever I need to do.- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- If run from a script, then the following are necessary: create_timing_netlist read_sdc update_timing_netlist --- Quote End --- Why this order? Intuitively I'd do it in this order: read_sdc create_timing_netlist Why this order will not work?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- Why this order? Intuitively I'd do it in this order: read_sdc create_timing_netlist Why this order will not work? --- Quote End --- You have to create the timing netlist before you can apply the sdc commands to it ... doesn't work the other way around.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
