17267 Discussions
[SDC] Input/Output delay for All ports -> script writing
Hi All,
How can I create the timing constraints (set_input/output_delay) for all ports (excepting clocks and reset ports)?
Let's say the design has the following clocks: clk0, clk1, clk2 and following resets: rstn0, rstn1, rstn2 and hundreds of other ports.
How can I write a script, which set input delays of 0ns for all input ports (excepting clk0, clk1, clk2, rstn0, rstn1, rstn2) and output delays of 0ns for all output ports?
Thank you!
I don't quite understand what you want to accomplish here. Your input and output delays could be 0 for a *minimum* delay, but you also need a matching *maximum* delay. The range of delay is required to give the Fitter an idea of what it has to work with as to the placement of the input or output register.
set_input_delay -clock <virtual clock that drives upstream device> -max [get_ports in*] <max external delay based on tco of upstream device and board delays>
set_input_delay -clock <virtual clock that drives upstream device> -min [get_ports in*] 0
set_output_delay -clock <virtual clock that drives downstream device> -max [get_ports out*] <max external delay based on tsu of downstream device and board delays>
set_output_delay -clock <virtual clock that drives downstream device> -min [get_ports out*] 0
Does the [get_ports out*] list all the output ports and [get_ports in*] list all the input ports?
How can I exclude certain ports from these listings?
Is it possible to work with collections here?
How to remove the input/output delay constraints from the certain ports?
Thank you!
When I run the get_ports out* command from Quartus console, I'm receiving the following errors?
Error:ERROR: Quartus Prime Tcl command "get_ports" is only available for use in the following executables: Error: quartus_fit Error: quartus_sta Error: while executing Error: get_ports out*
Why? How to fix?
I used in* and out* as examples. You have to put in your own port names.
this is exactly what I asked for :-) how to list ALL input ports without listing each port separately!
How can I make a collection (list) of ALL the input ports (something like 'create_collection all_inputs')?
Just use all_inputs or all_outputs as your collection.
running the all_inputs command gives the same result:
Error:ERROR: Quartus Prime Tcl command "all_inputs" is only available for use in the following executables: Error: quartus_fit Error: quartus_sta Error: while executing Error:"all_inputs"
So, what's the solution?
Can you show your sdc file?
It's very simple - just several lines...
set_time_format -unit ns -decimal_places 3 create_clock -name {clk} -period 10.000 -waveform { 0.000 5.000 } create_clock -name {fifo_rclk} -period 10.000 -waveform { 0.000 5.000 } set_input_delay -clock { clk } 5 set_output_delay -clock { clk } 5
Use something like:
set data_inputs [all_inputs]
set data_inputs [remove_from_collection [all_inputs] clk]
That will create a list without clock. If you want to remove something else, do another line:
set data_inputs [remove_from_collection $data_inputs reset]
Repeat as necessary. If you want to visually see what's in it, then do:
query_collection -all -report $data_inputs
Once correct, use in constraint:
set_input_delay -clock clk -max 0.0 $data_inputs
Then repeat for outputs
set_input_delay [get_ports * ] ... =====>the * wildcard covers all the input ports
remove_input_delay [get_ports clk] ===> will remove the input delay on the specified port
Same thing for output delay.
http://quartushelp.altera.com/15.0/mergedprojects/tafs/tafs/tcl_pkg_sdc_ver_1.5_cmd_remove_input_delay.htm
--- Quote Start ---
--- Quote End ---
OK, how could I list all the elements in these collections? What are the generated collections names?
--- Quote Start ---
--- Quote End ---
I have a TCL script that has these lines in it to create files with the various 'collections' contents listed:
set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan set chan foreach_in_collection element { puts $chan ] } close $chan
I tried to run the ferst example:
set chan [open "TQ_all_clocks.rpt" "w"]
foreach_in_collection element [all_clocks] {
puts $chan [concat $element : [get_object_info -name $element]]
close $chan
The 'all_clocks' command is not recognized (ran from the Tcl Console). I've got the following:
Error:ERROR: Quartus Prime Tcl command "all_clocks" is only available for use in the following executables:
Error: quartus_fit
Error: quartus_sta
Error:"all_clocks"
Error: invoked from within
Error:"foreach_in_collection element [all_clocks] { puts $chan [concat $element : [get_object_info -name $element]]}"
So, what's the problem? How could be fixed?
Thank you!
--- Quote Start ---
close $chan
Error: quartus_fit
Error: quartus_sta
Error:"all_clocks"
Thank you!
--- Quote End ---
Ok, so here is my complete example. Previously I just posted snippets but they need to be run in the correct context.
I run this on the command line:
$(QUARTUS_BIN)/quartus_sta -t generate_timing.tcl $(DESIGN) 10
Where the contents of the file generate_timing.tcl is as follows:
set projname set numpaths project_open $projname create_timing_netlist read_sdc set_operating_conditions -model slow -grade c update_timing_netlist report_timing -setup -npaths $numpaths -detail path_only -file "TQ_setup_slow.rpt" set_operating_conditions -model fast -grade c update_timing_netlist report_timing -hold -npaths $numpaths -detail path_only -file "TQ_hold_fast.rpt" report_exceptions -file "TQ_exceptions.rpt" set chan foreach_in_collection reg { puts $chan ] } close $chan set chan foreach_in_collection reg { puts $chan ] } close $chan set chan foreach_in_collection reg { puts $chan ] } close $chan set chan foreach_in_collection reg { puts $chan ] } close $chan set chan foreach_in_collection cell { puts $chan ] } close $chan set chan foreach_in_collection pin { puts $chan ] } close $chan set chan foreach_in_collection net { puts $chan ] } close $chan set chan foreach_in_collection port { puts $chan ] } close $chan set chan foreach_in_collection clk { puts $chan ] } close $chan set chan foreach_in_collection keeper { puts $chan ] } close $chan exit
where do you run the script? from outside of the Quartus? But ow can I run the same commands from the TCL Console (from inside of Quartus)?
--- Quote Start ---
--- Quote End ---
As I indicated I run the commands from the command line using this command:
quartus_sta -t generate_timing.tcl MY_DESIGN 10
so the tcl script is fed to the Quartus Static Timing Analyzer (quartus_sta) application.
So basically the tcl command script in the file is run on the TCL console within the quartus_sta application.
If run from a script, then the following are necessary:
set projname [lindex $quartus(args) 0]
set numpaths [lindex $quartus(args) 1]
Most scripts I run I launch TimeQuest on the project and double-click on Update Timing Netlist, which does the following:
read_sdc
At that point I run a timing analysis script or whatever I need to do.
--- Quote Start ---
read_sdc
--- Quote End ---
Why this order? Intuitively I'd do it in this order:
read_sdc
Why this order will not work?
--- Quote Start ---
read_sdc
--- Quote End ---
You have to create the timing netlist before you can apply the sdc commands to it ... doesn't work the other way around.
