17268 Discussions
SDRAM pin assignment tcl script issues
I have a problem with tcl script *sdram*_pin_assignments.tcl execution. I've added SDRAM UniPhy controller in my QSys project, then generated and run tcl script from tools/TCL Scripts menu. But after script execution there are no changes in my project's qsf file. I've tried this with 2 different projects: in the one there is HPS SDRAM controller while in the other there is Hard FPGA SDRAM controller UniPhy based. I'm not sure but I think such a problem arosed when I start working with 14.1 version of the software. Has someone met similar problem before? Any ideas?
--- Quote Start ---
--- Quote End ---
I haven't tried 14.1 yet.
You could try the scripts I have posted for the DE0-nano and the BeMicro-CV boards.
Post#2
http://www.alteraforum.com/forum/showthread.php?t=45927
Post#5
http://www.alteraforum.com/forum/showthread.php?t=43992
Cheers,
Dave
If you recently cleaned your project you'll need to perform a compilation first. After that the pin_assignments.tcl should work.
I'm having other issues with the fitter being unable to route several signals on the HPS HPHY though :\, just filed a support request. Happens with 14.1
