Arrays issue
I've been trying to code arrays lately (verilog newbie) and I'm having issues reading values inside them.
Narrowed issue down to a small code sample:
module arrays(LEDG); output LEDG; reg array; reg wat=0; initial begin array=8'hff; end //assign LEDG=array; assign LEDG=array; endmodule
First (commented) assign will return the correct value (0xff), second one won't (returns 0x00).
Cannot understand why, is there something about arrays usage I missed out? Didn't find much info.
Using Quartus 13.0.1
why not just assign LEDG to a constant?
assign LEDG[7:0] <= 8'hff;
It's just a small code snippet to illustrate the issue, I intend to fill variable values into the array in full project...
why not post the whole code then?
