17237 Discussions
To high result, serial fir filter VHDL
Hey, I'm beginner at VHDL and I have a problem with my serial fir filter with LUT:
LUT table: not all
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity lut_table is port( x0,x1,x2,x3,x4,x5,x6,x7,x8 : in std_logic; table_out : out std_logic_vector(13 downto 0) ); end lut_table; architecture arch of lut_table is signal table_in : std_logic_vector( 8 downto 0); begin table_in <= x8 & x7 & x6 & x5 & x4 & x3 & x2 & x1 & x0; with table_in select table_out <= "00000000000000" when "000000000", "00000001101110" when "000000001", "11111110111011" when "000000010", "00000000101001" when "000000011", "11111011000000" when "000000100", "11111100101110" when "000000101", "11111001111011" when "000000110", "11111011101001" when "000000111", "00010001000101" when "000001000", "00010010110011" when "000001001", "00010000000000" when "000001010", "00010001101110" when "000001011", etc. end arch.
Main unit:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.math_real.all; entity filtr_fir_da is port ( clk, rst : in std_logic; data_in : in std_logic_vector(7 downto 0); data_out : out std_logic_vector(27 downto 0) ); end filtr_fir_da; architecture arch of filtr_fir_da is signal acc_reg, acc_next : signed(27 downto 0); signal data_out_reg,data_out_next : signed(27 downto 0); signal tableout : std_logic_vector(13 downto 0); signal adress_reg, adress_next : unsigned (3 downto 0); signal d0_reg,d1_reg,d2_reg,d3_reg,d4_reg,d5_reg,d6_reg,d7_reg,d8_reg : std_logic; signal d0_next,d1_next,d2_next,d3_next,d4_next,d5_next,d6_next,d7_next,d8_next : std_logic; type x_table is array (0 to 8) of std_logic_vector(7 downto 0); signal datat_reg,datat_next : x_table; type STYPE is (load,count,result); signal state_reg, state_next : STYPE; component lut_table port( x0,x1,x2,x3,x4,x5,x6,x7,x8 : in std_logic; table_out : out std_logic_vector(13 downto 0) ); end component; begin lut: lut_table port map( x0 => d0_reg,x1 => d1_reg,x2 => d2_reg,x3 => d3_reg,x4 => d4_reg,x5 => d5_reg,x6 => d6_reg,x7 => d7_reg,x8 => d8_reg, table_out => tableout ); process(rst,clk) begin if rst = '1' then state_reg <= load; elsif rising_edge(clk) then state_reg <= state_next; end if; end process; process(rst, clk) begin if rst = '1' then adress_reg <= "0000"; data_out_reg <= (others => '0'); acc_reg <= (others => '0'); datat_reg <= (others => (others => '0')); d0_reg <= '0'; d1_reg <= '0'; d2_reg <= '0'; d3_reg <= '0'; d4_reg <= '0'; d5_reg <= '0'; d6_reg <= '0'; d7_reg <= '0'; d8_reg <= '0'; elsif rising_edge(clk) then adress_reg <= adress_next; acc_reg <= acc_next; data_out_reg <= data_out_next; datat_reg <= datat_next; d0_reg <= d0_next;d1_reg <= d1_next;d2_reg <= d2_next;d3_reg <= d3_next;d4_reg <= d4_next;d5_reg <= d5_next;d6_reg <= d6_next;d7_reg <= d7_next;d8_reg <=d8_next; end if; end process; process(state_reg,adress_reg,data_out_reg,d0_reg,d1_reg,d2_reg,d3_reg,d4_reg,d5_reg,d6_reg,d7_reg,d8_reg,acc_reg,datat_reg,datat_next,tableout,data_in) begin state_next <= state_reg; adress_next <= adress_reg; acc_next <= acc_reg; data_out_next <= data_out_reg; datat_next <= datat_reg; d0_next <= d0_reg;d1_next <= d1_reg;d2_next <= d2_reg;d3_next <= d3_reg;d4_next <= d4_reg;d5_next <= d5_reg;d6_next <= d6_reg;d7_next <= d7_reg;d8_next <= d8_reg; case state_reg is when load => datat_next(8) <= datat_reg(7); datat_next(7) <= datat_reg(6); datat_next(6) <= datat_reg(5); datat_next(5) <= datat_reg(4); datat_next(4) <= datat_reg(3); datat_next(3) <= datat_reg(2); datat_next(2) <= datat_reg(1); datat_next(1) <= datat_reg(0); datat_next(0) <= data_in; state_next <= count; when count => if adress_reg < "0111" then d0_next <= datat_reg(0)(to_integer(adress_reg)); d1_next <= datat_reg(1)(to_integer(adress_reg)); d2_next <= datat_reg(2)(to_integer(adress_reg)); d3_next <= datat_reg(3)(to_integer(adress_reg)); d4_next <= datat_reg(4)(to_integer(adress_reg)); d5_next <= datat_reg(5)(to_integer(adress_reg)); d6_next <= datat_reg(6)(to_integer(adress_reg)); d7_next <= datat_reg(7)(to_integer(adress_reg)); d8_next <= datat_reg(8)(to_integer(adress_reg)); acc_next <= (shift_left(signed(tableout),to_integer(adress_reg))) + acc_reg; adress_next <= adress_reg + "0001"; state_next <= count; elsif adress_reg = "0111" then d0_next <= datat_reg(0)(to_integer(adress_reg)); d1_next <= datat_reg(1)(to_integer(adress_reg)); d2_next <= datat_reg(2)(to_integer(adress_reg)); d3_next <= datat_reg(3)(to_integer(adress_reg)); d4_next <= datat_reg(4)(to_integer(adress_reg)); d5_next <= datat_reg(5)(to_integer(adress_reg)); d6_next <= datat_reg(6)(to_integer(adress_reg)); d7_next <= datat_reg(7)(to_integer(adress_reg)); d8_next <= datat_reg(8)(to_integer(adress_reg)); acc_next <= -(shift_left(signed(tableout),to_integer(adress_reg))) + acc_reg; adress_next <= "0000"; state_next <= result; end if; when result => data_out_next <= acc_reg; state_next <= load; acc_next <= (others => '0'); when others => state_next <= load; end case; end process; data_out <= std_logic_vector(data_out_reg); end arch;
My scale coefficients are
[ 110,-69,-320,1093,2470,1093,-320,-69,110]
For example when input signal is
[1,0,0,0,0,0,0,0,0]
my system multiple the reuslt twice so the result is
[ 220,-138, -640, 2186, 4940, 2186, -640, -138, 220]
instead
[110, -69, -320, 1093, 2470, 1093, -320, -69, 110].
Anyone help ? I think there is something wrong with last cycle of count state, because the result is delayed 10 cycles of clock, so all system count the result badly but I don't know how I can repair it ;/
can you formt your code with some newlines please?
