Tool: SOPC Builder 9.1, SP2
Action: In SOPC Builer, after you add old 'class.ptf' based component (maybe from: C:\altera\91\ip\altera\sopc_builder_ip\) and then press 'Generate', you may get error as follows: Error: One or more components could not be located (MODULE_NAME) SOLUTION -------- First, exit SOPC Builer with 'Save' changes. Then open text file located in: /YOUR_PROJECT_DIR/.sopc_builder/install.ptf You can find many WRONG paths as following example: local = "c:/altera/91/quartus//../ip/altera/nios2_ip/altera_nios2"; Delete text 'quartus//../' in each 'local' parameter, then save this file. Re-run SOPC Builder and generate the system. At first I think this issue is introduced by text '//', but thanks to akira's post: http://www.alteraforum.com/forum/showthread.php?t=24959 it seems OK for text '//'. Same condition can be found in: /altera/91/ip/.sopc_builder/install.ptf BUT it DOESN'T make problem... (why???) Hope this post is helpful.Link Copied
My error msg was different : ISP1362:avalon_slave_1_irq:"associated addressable interface"(assocaitedAddressablePoint) out of range.. could you pl tell me if anything can be done, i got this error when i tried to update older sopc .ptf file to .sopc file,
