17267 Discussions
constant expression cannot contain a hierarchical identifier
Hi people,
I'm very new to SystemVerilog, and learning how to write synthesizable code right now. Could you help me with an issue?
Please take a look at the code:
typedef struct{ int a; int b; int c; } params_t; module A (clk, rst, out); parameter params_t params = '{2, 3, 4}; input logic clk, rst; output logic out; //line 12! always @ (posedge clk, posedge rst) begin if(rst == 1'b1) begin out <= '0; end else begin out <= out + params.b; end end endmodule
Quartus II (9.1) gives an error at the line 12:
"constant expression cannot contain a hierarchical identifier"
The problem seems to be that I want to use parameters defined in a structure to make the design more generic. With VHDL it works fine. Am I allowed to do it in SV, or is it just Quartus issue? It would work if I would use the parameters without putting them into a structure, but it's ugly. How would you do it on my place?
