17254 Discussions
SOPC Builder - System Generation Error
I have a strange error when generating a system including an On-Chip FIFO Memory component.
The generation process stops with the following error:
# 2008.04.04 16:50:12 (*) Running Generator Program for onchip_fifo_mem
ERROR:
no names in concatenation
Error: Generator program
for module 'onchip_fifo_mem' did NOT run successfully.
generator cmd was 'e:/altera/71/quartus//bin/perl/bin/perl -Ie:/altera/71/quartus//sopc_builder/bin -Ie:/altera/71/quartus//sopc_builder/bin/europa -Ie:/altera/71/quartus//sopc_builder/bin/perl_lib -I/cygdrive/e/altera/71/quartus//sopc_builder/bin/perl_lib:/cygdrive/e/altera/71/quartus//sopc_builder/bin/europa:/cygdrive/e/altera/71/quartus//sopc_builder/bin: -I. -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_fifo -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_pio -IE:/altera/71/ip/nios2_ip/altera_nios_custom_instr_interrupt_vector -IE:/altera/71/ip/nios2_ip/altera_nios_custom_instruction -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_onchip_memory2 -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_onchip_memory -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_mutex -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_burst_adapter -IE:/altera/71/ip/pci_express_compiler/lib/sopc_builder/altera_avalon_pcie_compiler_adapter -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_cf -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_spi -IE:/altera/71/ip/pci_compiler/lib/sopc_builder/altera_avalon_pci_compiler -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_user_defined_interface -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_pipeline_bridge -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_stratix_2s60_rohs -IE:/altera/71/ip/nios2_ip/altera_nios_custom_instr_bitswap -Ie:/altera/71/quartus//sopc_builder/components/altera_sopc_builder -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_cfi_flash -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_pll -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_sgdma -IE:/altera/71/ip/nios2_ip/altera_nios_custom_instr_floating_point -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_epcs_flash_controller -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_adapter_upstream_pipeline -IE:/altera/71/ip/nios2_ip/altera_nios_dev_kit_stratix_edition_sram -IE:/altera/71/ip/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet -IE:/altera/71/ip/pci_express_compiler/lib/sopc_builder/altera_avalon_pcie_compiler -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_lan91c111 -IE:/altera/71/ip/nios2_ip/altera_nios_dev_kit_stratix_edition_sram2 -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_adapter_downstream_pipeline -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_stratix_1s40 -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_uart -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_new_sdram_controller -IE:/altera/71/ip/ddr2_high_perf/lib/sopc_builder/ddr2_high_perf -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_adapter_waitrequest_pipeline -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_adapter_slave_y -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_clock_adapter -IE:/altera/71/ip/pci_compiler/lib/sopc_builder/altera_avalon_pci_compiler_adapter -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_mailbox -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_asmi -Ie:/altera/71/quartus//sopc_builder/components/amd_avalon_am29lv065d_flash -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_lcd_16207 -IE:/altera/71/ip/nios2_ip/altera_nios_custom_instr_endian_converter -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_jtag_uart -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_adapter_master_y -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_endian_adapter -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_cyclone_1c20 -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_stratix_1s10_es -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_tri_state_bridge -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_cyclone_2c35 -Ie:/altera/71/quartus//sopc_builder/
components/no_legacy_module -Ie:/altera/71/quartus//sopc_builder/components/amd_avalon_am29lv128m_flash -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_cy7c1380_ssram -IE:/altera/71/ip/nios2_ip/altera_nios2 -IE:/altera/71/ip/ddr_ddr2_sdram/lib/sopc_builder/ddr_sdram_component -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_cs8900 -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_performance_counter -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_sysid -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_fifo -IE:/altera/71/ip/ddr_high_perf/lib/sopc_builder/ddr_high_perf -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_stratix_2s60_es -IE:/altera/71/ip/ddr_ddr2_sdram/lib/sopc_builder/ddr2_sdram_component -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_timer -IE:/altera/71/ip/nios2_ip/altera_nios_multiply -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_dma -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_stratix_1s10 -Ie:/altera/71/quartus//sopc_builder/components/altera_avalon_clock_crossing -IE:/altera/71/ip/nios2_ip/altera_nios_dev_board_stratix_2s60 e:/altera/71/quartus//sopc_builder/components/altera_avalon_fifo/em_fifo.pl --system_name=SimpleDev2 --target_module_name=onchip_fifo_mem --system_directory=E:/!work/SimpleDevice2 --sopc_directory=e:/altera/71/quartus//sopc_builder --sopc_lib_path=E:/!work/SimpleDevice2+E:/altera/71/ip/pci_express_compiler/lib/sopc_builder+E:/altera/71/ip/ddr2_high_perf/lib/sopc_builder+E:/altera/71/ip/ddr_high_perf/lib/sopc_builder+E:/altera/71/ip/sopc_builder_ip+E:/altera/71/ip/nios2_ip+E:/altera/71/ip/triple_speed_ethernet/lib/sopc_builder+E:/altera/71/ip/pci_compiler/lib/sopc_builder+E:/altera/71/ip/ddr_ddr2_sdram/lib/sopc_builder+e:/altera/71/quartus/common/librarian/factories+e:/altera/71/quartus/sopc_builder/model/lib+e:/altera/71/ip/pci_compiler/lib/ip_toolbench+e:/altera/71/ip/pci_express_compiler/lib/ip_toolbench+e:/altera/71/ip/rapidio/lib/ip_toolbench+e:/altera/71/ip/ddr2_high_perf/lib/ip_toolbench+e:/altera/71/ip/ddr_high_perf/lib/ip_toolbench+e:/altera/71/ip/triple_speed_ethernet/lib/ip_toolbench+e:/altera/71/quartus//sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=e:/altera/71/quartus//sopc_builder/components/altera_avalon_fifo --sopc_quartus_dir=e:/altera/71/quartus/ --projectname=SimpleDevice2.qpf'
Error in processing. System NOT successfully generated.
Any Ideas how I can avoid that error?
