17254 Discussions
SOPC Builder error:PTF failed!
Hi everybody!
when building Sopc system i get this error:
Error: Failed to refresh PTF file U:/MY_PROJECT/test/cpu.ptf (-1)
i use quartus10.1 on win7.I have never had a problem when using quartus on win XP.
i have uninstalled and install quartus again,but still have the same problem.
is that a support problem?is there something to do and how can i workaround?
thank you for replying me.
Sounds like a file permission problem to me. Try creating a new simple system from scratch and see if it can access your mapped location correctly.
what do you mean with "file permission problem" ?Is there a way to set this permission?
Can you help me workaround it?
sorry i have forgotten a relevant part of this error.The whole error is:
Error: Failed to refresh PTF file U:/MY_PROJECT/test/CPU.ptf (-1)
Executing: I:/programme/altera/10.1/quartus//sopc_builder/bin/sopc_builder --classic
Error: Couldn't run process I:/programme/altera/10.1/quartus//sopc_builder/bin/sopc_builder --classic --generate U:/MY_PROJECT/test/CPU.ptf successfully
I have tried with an altera design example , but it is the same error :
Error: Failed to refresh PTF file U:/CYC3/niosii_ethernet_standard_3c25/sopc_system.ptf (-1)
Info: Finished elaborating PTF file.
Executing: I:/programme/altera/10.1/quartus//sopc_builder/bin/sopc_builder --classic --generate U:/CYC3/niosii_ethernet_standard_3c25/sopc_system.ptf
Error: Couldn't run process I:/programme/altera/10.1/quartus//sopc_builder/bin/sopc_builder --classic --generate U:/CYC3/niosii_ethernet_standard_3c25/sopc_system.ptf successfully
Thank you for answering me!
At that stage it's attempting to write to the .ptf file so if there is a write permission problem then these steps will fail.
If you navigate to the .ptf file on the mapped drive, right click it, and select properties you'll be able to see the file permissions. It could be set to read only or the machine you are accessing the file from doesn't have write permission to the file. Perhaps Microsoft changed something with network file accessing that is causing this issue (not sure since I typically try to keep my project files local for compilation speed reasons).
I have problem like you, so you fix this problem yet?
Can you help me to fix this problem
Executing: C:/altera/91sp2/quartus//sopc_builder/bin/sopc_builder --classic --generate C:/altera/lab_Nios/lab_1/nios_system.ptf
Error: Couldn't run process C:/altera/91sp2/quartus//sopc_builder/bin/sopc_builder --classic --generate C:/altera/lab_Nios/lab_1/nios_system.ptf successfully
Error: System generation failed.
