I had Quartus II 10.1fb installed and everything worked fine. I installed 10.1 and opened an existing project and now it's generating Verilog files instead of VHDL.
Quartus II -> Tools -> Options: HDL preference is set to VHDL SOPC Builder System Generation tab says the following above the "Simulation. Create project simulator files." check box: "System module logic will be created in Verilog." What gives? I can't find any way to specify the preferred language in SOPC Builder.Link Copied
you select an HDL when you initially create the SOPC Builder system. you can still change it by editing the .sopc file in a text editor. change the line(s) that say Verilog to VHDL
Perfect! That did the trick! Thanks!
