17254 Discussions
Schematic Symbol Parameter in Hex
pertrl
how can I input a hexadecimal value in the parameter table of a block diagram/schematic file (.bdf)?
behind the block is the following VHDL code:
entity reg is
	generic (
		constant REG_BASE_ADDR : natural := 16#4010#;
	port (
end;
every variant I could imagine results in an error like:
Parameter     | Value   | Type
REG_BASE_ADDR | x"4010" | Auto
Error (10515): VHDL type mismatch error at reg.vhd(17): natural type does not match string literal
ShengN_Intel
Done testing. Use the following for example:
addr : std_logic_vector(15 downto 0) := x"FFFF"
Then change line 16 from:
signal reg : std_logic_vector(15 downto 0) := std_logic_vector(to_unsigned(addr, 16));
to:
signal reg : std_logic_vector(15 downto 0) := addr;
You'll be able to use Hexadecimal type for example value AAAA
Sheng
sstrell
Assuming you are using Standard or Lite, you may be running into the limited VHDL 2008 support there: https://community.intel.com/t5/Programmable-Devices/Does-Quartus-20-1-std-support-VHDL-2008-vector-aggregation/m-p/1468730#M90058%3Fwapkw=Error%2010515
FvM
the problem doesn't seem related to VHDL support in my view. You can neither send a hexadecimal literal to a numerical Verilog module parameter. Only decimal numbers seem to be accepted as block parameters for numerical values.
pertrl
I'm using Quartus Prime Lite 22.1.2 and 23.1
With verilog it works for me like so:
REG_BASE_ADDR | 4002  | Hexadecimal
But something like X"4000" or 16#4000# is not a VHDL-2008 thing, or is it?
ShengN_Intel
To input a hexadecimal value in the parameter table of a block diagram/schematic file (.bdf), set the (Type) to either Auto or Hexadecimal then under (Value) straight away give a value for example like: a, not need the symbol x""
Sheng
pertrl
This does not work. here is some test code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test2 is
	generic (
		addr : natural := 16#4000#
	port (
		i_clk : in std_logic;
		o	   : out std_logic_vector(15 downto 0)
end;
architecture arch of test2 is
begin
	o <= reg;
end;
generating a symbol from this code results in the following table:
addr      | 16384 | Signed Integer
and synthesizes correctly to
using
addr       | 4000  | Hexadecimal
results in an error:
Error (10515): VHDL type mismatch error at /asd.vhd(8): natural type does not match string literal
using
addr      | 4000  | Auto
 synthesizes incorrectly to:
ShengN_Intel
May I know which block you're using in .bdf?
Sheng
pertrl
The one you get by clickling File -> Create/Update -> Create Symbole Files from Current File in the*.vhd file.
the upper block with with Verilog works, VHDL does not.
ShengN_Intel
to:
Sheng
pertrl
Not exactly the same, but it will do, thanks.
