17255 Discussions
Sending DATA FROM LAPTOP TO DE2
Hello
I am very very green to altera and i am facing a difficult problem .
I Need to create communication link between DE2 board to laptop.(basically i am simulating transmitter and receiver laptop is transmitter and fpga (DE2 board) is receiver.)
What is the eseyest way to do it?from what i red at DE2 datasheet there is an usb connector so i was thinking to connect usb to usb cable from laptop to DE2.
Laptop will see it as a virtual com but what will see the DE2 and how do i recive the data?
Thx.
Thx
I Was not sure were to place the question.
Any idea how to solve it?
If there is an FTDI usb to com converter, your laptop will be able to send/receive com port data's on the virtual com port,
in your fpga you can then use/drive the uart lines.
Thx,So bsicly from what i understand i need to buy a cable tha on side will be usb that i will see on my laptop as virtual com and on another side it will be rs232 that will be connected to fpga DE2,
Do i need to use nyos2 for reading data from the uart that operating RS232 on the DE2 board or i can read it like in micro controllers evaluation board with already build drivers something like include uart.h and then just use red and write ?
Thx!!!!!
Yes. I do not know the détails for the uart in your fpga, sorry.
Thx, If you will be so kind pls take a look this is my board
http://www.altera.com/education/univ/materials/boards/de2/unv-de2-board.html
Thank you very much!!!!!!!!!!!!!
The DE2 board already has a serial interface (RS232).
Your NIOS system needs to instantiate a UART, and that UART can be used to communicate with your PC.
The data bandwidth over the link will be limited by the UART BAUD rate, eg., 115.2kbaud.
If you need a faster data rate, then look at using the network interface.
If you can deal with a slower interface, then look at using the JTAG interface
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
Cheers,
Dave
