Sequence of operations
Hi there,
I'm trying to build a module that initializes an LCD and at the beginning a series of operations must be performed to initialize the LCD, so far a solution is to use a counter and decode each step into the required series of data sent to the LCD.
I'm new to HDL and was wondering what other solutions are available?
Thank you.
I would think more along the lines of a state machine than a counter, but either approach would work. A state machine would be more flexible and IMO easier to look at and debug.
Hope that helps.
I gues this aproach is somewhat better. I was also thinking of a LUT for each step but a state machine sounds better.
