Serial in, Parallel out
Hi..
I have very basic question.I am sorry but i could not able to solve it so i m posting here.
In my project,
I have
clk:in bit;
SI : in std_logic;
PO : out std_logic_vector(12 downto 1);
here
SI = 11001011001
and i want parallel output like..
PO(1) =1 ;
PO(2) =0 ;
PO(3) =0 ;
PO(4) =1 ;
PO(5) =1 ;
PO(6) =0 ;
PO(7) =1 ;
PO(8) =0 ;
PO(9) =0 ;
PO(10) =1 ;
PO(11) =1 ;
What are the best options for this application (VHDL or schematic) ??
Thanking you.
HI I wil give you a favor. But your question is not clear. SI
is SI serial? If you give me a more detail, I will give you a example.
Hi...
Yes SI is the serial input (SI = 11001011001) and i want parallel output like..
PO(1) =1 ;
PO(2) =0 ;
PO(3) =0 ;
PO(4) =1 ;
PO(5) =1 ;
PO(6) =0 ;
PO(7) =1 ;
PO(8) =0 ;
PO(9) =0 ;
PO(10) =1 ;
PO(11) =1 ;
This is like Serial interface..
I hope it will be clear now.
Thanks a lot
Try something like this:-
shift_register : process(clk)
begin
if rising_edge(clk) then
shift_reg(12 downto 1) <= shift_reg(11 downto 1) & SI;
end if;
end process shift_register;
PO <= shift_reg;
