17252 Discussions
Setting up Quartus II 13.1 error message
shann1
Hi, I hope I'm posting in the correct place.
I installed Quartus II 13.1 on my Linux Mint Sylvia 18.3. I made sure to install the 32-bit dependencies that I found listed on this site:
http://mattaw.blogspot.com/2014/05/making-modelsim-altera-starter-edition.html Matthew's Mumblings: Making ModelSim ALTERA STARTER EDITION vsim 10.1d work on Ubuntu 14.04
I noticed no error messages during or after install. But when I try to open Quartus, I get the following:
First off, when it asked to Retrieve the Web License it won't connect. I had read that these web versions that need a license.
Secondly, this error message, beyond which I cannot proceed
*** Fatal Error: Segment Violation at (nil)
Module: quartus
Stack Trace:
0x85ce3: lh_insert + 0xb3 (tls1.6)
0x7a48c: OBJ_NAME_add + 0x6c (tls1.6)
0x4bba8: SSL_library_init + 0x38 (ssl.so.1.0.0)
0x1a0056: QObject::event(QEvent*) + 0x376 (QtCore.so.4)
0x1fd924: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0xb4 (QtGui.so.4)
0x2024df: QApplication::notify(QObject*, QEvent*) + 0x12f (QtGui.so.4)
0x18b27c: QCoreApplication::notifyInternal(QObject*, QEvent*) + 0x8c (QtCore.so.4)
0x18e8a8: QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 0x328 (QtCore.so.4)
0x18a062: QEventLoop::processEvents(QFlags) + 0x32 (QtCore.so.4)
0x18a31d: QEventLoop::exec(QFlags) + 0x14d (QtCore.so.4)
0x18ed4b: QCoreApplication::exec() + 0xbb (QtCore.so.4)
0x7dc1: __gxx_personality_v0 + 0x3b9 (quartus)
0x3bb9a: msg_main_thread(void*) + 0x10 (ccl_msg)
0x75bc: thr_final_wrapper + 0xc (ccl_thr)
0x3c801: msg_thread_wrapper(void* (*)(void*), void*) + 0x5b (ccl_msg)
0x16e45: mem_thread_wrapper(void* (*)(void*), void*) + 0xc5 (quartus)
0xf41d: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x799c: thr_thread_wrapper + 0x15 (ccl_thr)
0x4e41d: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x96 (ccl_msg)
0x7e85: __gxx_personality_v0 + 0x47d (quartus)
0x20830: __libc_start_main + 0xf0 (c.so.6)
0x7c99: __gxx_personality_v0 + 0x291 (quartus)
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full Version
Can anyone suggest the right course of action to get Quartus II working on my work-station?
Thank you
CarlosAM_INTEL
Hello, kostoglotov:
Your consultations related to the cited product should be addressed to the following website:
https://forums.intel.com/ https://forums.intel.com/
We hope that this information may help you.
Carlos_A.
