17253 Discussions
Signal Tap Autorun Analysis Log
yossik
Is there a way to log into a file all the data acquired during singal tap autorun analysis? Meaning,  capture the data of each one of the triggers, not only the latest trigger.
ShengN_Intel
The log will only record the latest trigger. May be you can create multiple instances to record the different triggers.
Sheng
ShengN_Intel
If I not mistaken, you mean to combine all the data log files (check screenshot below) into one log file right? If that's the case, there's no option to do that. Can check this link as well https://community.intel.com/t5/Intel-Quartus-Prime-Software/Signal-Tap-Combine-many-Data-Logs-to-one-file/m-p/1326279
Sheng
