17251 Discusiones
[SignalTap] Hot to trigger on the NOT condition
amildm
Colaborador Valioso I
636 Vistas
Hi All,
I have a 16-bits bus added to SignalTap.
So, what conditions should I set in the SignalTap so that it will be triggered on any value on the bus, which is different from 0x5555?
Thank you!
0 kudos
4 Respuestas
sstrell
Colaborador Distinguido III
624 Vistas
Hmm, never thought about doing that.  I guess you should check if there is a NOT object when building an Advanced Trigger.  Or you could create an advanced trigger that ORs <0x5555 and >0x5555 comparisons.
Or you could create 2 trigger conditions.  The first one would be a basic AND trigger for 0x5555.  In the second trigger condition column, you'd set each bit to look for "either edge" transitions so the logic analyzer would ultimately trigger any time a bit switched away from 0x5555.
RichardTanSY_Altera
599 Vistas
May I know does the suggestion from sstrell helps?
RichardTanSY_Altera
575 Vistas
Since there are no feedback for this thread, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
amildm
558 Vistas
I'm testing the solution, will provide my feedback a bit later.
Responder
