17252 Discussions
SignalTap and Cyclone VI
Hello. I have strange problem with SignalTap and Cyclone IV. There are fault responses. Frequency is low (50 MHz) and I don't know what to do
Are you sampling on the right clock? Are your observations correct?
Do you have timing violations(low clock does not mean no timing violations)?
--- Quote Start ---
--- Quote End ---
Try a more meaningful report!
There is a simple code
tp1 <= tp1_as;
process (fpga_reset_h, sys_clk_int) is
begin
if(fpga_reset_h = '1') then
--tp1 <= '0';
tp2 <= '0';
tp3 <= '0';
ser_txd <= '1';
elsif(rising_edge(sys_clk_int)) then
tp2 <= tp2_as;
tp3 <= tp3_as;
ser_txd <= ser_rxd;-- Synchronous Sequential Statement(s)
end if;
end process;
a1 : ENTITY work.spll
PORT MAP
areset => fpga_reset_h,
inclk0 => sys_clk,
c0 => sys_clk_int,
c1 => tp1_as,
c2 => tp2_as,
locked => tp3_as
There are no timing violations. SCD file contain correct clock constrains.
SignalTap connected to sys_clk_int and tp1, tp2, tp3.
SignalTap start off-loading data at some moment, but I don't see any graphical data. Pressing "Read Data" button gives result that looks like valid data at incorrect trigger condition
I had a similar problem when using a USB blaster that didn't came from Altera and running signaltap on the linux platform. It seemed that some ftdi drivers messed up a bit the data collected from the blaster and it got shifted a bit. I don't know if you are in a similar situation.
Can you route those signals to an FPGA pin and check them with a scope?
My USB blaster didn't came from Altera. But I have no any problem with previous design based on Cyclone III family. I use Windows7
TP1..3 are testpoints and I checked them with a scope. I didn't see any problems.
Thanks for reply
