17266 讨论
SignalTapII and NIOSII processor
名誉分销商 II
1,496 次查看
Is it possible to use SinalTapII with NIOSII processor with Quartus 9.1 or 10.0 web ?
It's appeared the "OpenCore Plus Status" which blocks QuartusII to work with SignalTapII.
Thank you.
0 项奖励
7 回复数
名誉分销商 II
744 次查看
It is annoying, but possible. What you can do is to run the Quartus programmer outside of Quartus (look for the quartus_pgmw.exe application in the Quartus bin folder). That way you can still use Quartus even with the Opencore window blocking the programmer.
0 项奖励
名誉分销商 II
744 次查看
Thanks, daixiwen (http://www.alteraforum.com/forum/member.php?u=4443)!
It's working.
It's for not a big progects like my one. It request very large onchip memory and NIOSII processor request too. If you want to analize big project it will be better to use ModelSim. I've never used it for a project with NIOSII processor. Is it possible to use ModelSim for a project built
with SOPC builder and with NIOSII processor? If it's possible what's the simplest way to transfer the code's files from QuartusII to ModelSim and back. I usually made copies of ones from QuartuII's project to ModeiSim's one. One thing to remember ModelSim's library requests pll name 'PLL1'. You can name altpll 'PLL1' from SOPC builder.
Thanks in forward!
Cordialy,
Mike.
0 项奖励
名誉分销商 II
744 次查看
You can invoke Modelsim directly from Quartus. You need to define it as the external simulator to use. I don't have Quartus here to check out how it is done but it should probably be described somewhere in the manual
0 项奖励
名誉分销商 II
744 次查看
Tools > Options > EDA Tool Options
set the path to the ModelSim-AE aloem-something-or-other directory
then read about NativeLink:
http://www.altera.com/literature/hb/qts/qts_qii5v3_01.pdf
0 项奖励
名誉分销商 II
744 次查看
It has the usefull information.
0 项奖励
名誉分销商 II
744 次查看
It requests licenced software.
0 项奖励
名誉分销商 II
744 次查看
make sure you have ModelSim-Altera Starter Edition which is free. ModelSim-Altera Edition requires a license
0 项奖励
回复
