17255 Discussions
system verilog in Quartus
I can't understand system verilog.
I'm make two interfaces:
typedef struct { logic dma_start; logic dma_end; logic dma_status; logic dma_ctrl; }dma_rx_t; interface regs_if; dma_rx_t dma0_rx; endinterface interface pcie_rx_if; logic rx_ack ; wire rx_ws ; wire rx_req ; wire rx_desc ; wire rx_data ; wire rx_be; wire rx_dv ; wire rx_dfr ; endinterface make my module:
module artem_memio_if ( input bit clk, input bit rstn, regs_if regs, pcie_rx_if pcie_rx ); (* keep = 1 *) wire rx_bar_hit_n; assign rx_bar_hit_n = (pcie_rx.rx_desc | pcie_rx.rx_desc) ? 1'b1 : 1'b0; upper level module:
module altpcierd_cdma_app_icm ( ….. input rx_desc0 , … ); regs_if regs(); pcie_rx_if pcie_memio_rx(); assign pcie_memio_rx.rx_req = rx_req0; assign pcie_memio_rx.rx_desc = rx_desc0; assign pcie_memio_rx.rx_data = rx_data0; assign pcie_memio_rx.rx_desc = rx_desc0; assign pcie_memio_rx.rx_dv = rx_dv0; assign pcie_memio_rx.rx_dfr = rx_dfr0; artem_memio_if artem_memio( .clk(clk_in), .rstn(rstn), .regs(regs), .pcie_rx(pcie_memio_rx) ); But quartus say:
--- Quote Start ---
Error: Net "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_memio_rx.rx_desc[129]", which fans out to "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_rx_if:pcie_memio_rx|pcie_rx_if.rx_desc[129]", cannot be assigned more than one value
Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_memio_rx.rx_desc[129]"
Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_rx_if:pcie_memio_rx|pcie_rx_if.rx_desc[129]"
Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|artem_memio_if:artem_memio|pcie_rx.rx_desc[129]
--- Quote End ---
i don't know System Verilog, but have you tried loading the same HDL in ModelSim to see if there is a discrepancy in tool behavior?
