17259 Discussions
Signaltap: discontinuty length in conditional traces
Is it possible to get signaltap to show a true timeline when conditional storage is enabled?
I'm trying to track down some issues with latency on PCIe requests (which can take 256+ clocks at the best of times) but I think are being stalled for several 100us.
I can suppress the storing of data while the PCIe request is in progress - but then I've no idea how long it took.
I'm probably looking for something more like the 'transitional mode' of some HP logic analisers.
I traced a 32bit clock counter.
The discrepency is 2156000 counts of the 62.5MHz 'application' clock.
I make that 34.5ms - far longer than I ever imagined.
So I don't think they can be 'normal' latency issues.
I can only imagine that something like a PCIe retrain has happened.
--- Quote Start ---
--- Quote End ---
That was what I was about to suggest. I did that for these PCIe related traces (see p17)
http://www.ovro.caltech.edu/%7edwh/correlator/pdf/altera_pcie_analysis.pdf
I was disappointed with the Altera PCIe core, so did not end up using it. Otherwise I might be more help :)
I don't suppose you know someone with a PCIe bus analyzer ... I'm sure one of those would trace the transactions and tell you what is going wrong ...
Worst-case how about a PCIe host that you can control, eg., an ARM or PowerPC root-complex running U-Boot? You could sequentially perform the PCIe enumeration stages and see where it dies.
Cheers,
Dave
It all works 'most of the time', the root-complex is an intel atom board.
PCIe read bursts usually take 128-256 clocks depending on the actual length.
Writes are all posted and only have a delay of about 8 clocks + the data transfer clocks.
I've have to write a simple multi-channel dma controller to generate the burst transfers.
--- Quote Start ---
--- Quote End ---
Sorry to hear that, that makes it really hard to debug.
--- Quote Start ---
--- Quote End ---
If your PCIe setup allows you to plug in two of your end-point devices, then it might be easier to setup DMA transfers between the two end-points, rather than the end-point to root-complex.
I've used this scheme to debug PCI boards. Eg., I'll put the PowerPC processor on the PCI peripheral boards in reset, and then from the x86 host memmap the PCI board registers, program the DMA controller of one board to transfer to the other, and then read/write to the memory on the PowerPC board. This saves having to write a custom driver, and is "low-level" enough for me to know what is exactly happening.
You could do much the same thing ...
Cheers,
Dave
In our case the linux driver on the x86 host is simple enough anyway.
It supports:
1) pread/pwrite through to the fpga BAR space.
2) mmap() of both BAR space and the fpga's PCIe master window (allocating physmem as needed).
There might be some suitable status info on the fpga - but it is a bit thin!
Also I didn't think PCIe supported transfers between two endpoints.
--- Quote Start ---
It supports:
--- Quote End ---
In the case of using DMA on the FPGA board, you need to reserve some memory to DMA into or from. I've written simple drivers for the x86 that allocate memory and print the physical address to the dmesg buffer. You can then manually program DMA controller registers to move data to/from the board. I'm pretty sure the code is in here (for an older kernel, so might need tweaking)
https://www.ovro.caltech.edu/~dwh/correlator/pdf/cobra_driver.pdf
https://www.ovro.caltech.edu/~dwh/correlator/software/cobra_driver.tar.gz
--- Quote Start ---
--- Quote End ---
I'm pretty sure you can. The root-complex BIOS/bootloader sets up the PCIe bus addresses. If you program a PCIe end-point with host addresses that correspond to another PCIe end-point, the DMA will go from the end-point to the PCIe switch (or root-complex) over to the destination PCIe end-point. As far as software is concerned, it should work just like PCI. :)
Cheers,
Dave
Yes, I've no problem writing unix (various) kernel code and device drivers.
So verifying/exercising the dma and pcie is relatively easy.
The failure rate seems to depend on the pattern of pcie transfers - changing the buffer size of my 'reflect data' test (actually reflect over my hdlc link as well) changes the error rate.
I'm going to see if the 'test_out' signals show anything interesting.
--- Quote Start ---
--- Quote End ---
Ok.
--- Quote Start ---
--- Quote End ---
If you were to use two PCIe end-points; one as the PCIe master and the other as the PCIe slave, you would be able to SignalTap II both ends of the PCIe transaction. If you had say an external 1pps signal or a trigger signal, you could use that to start a counter synchronously on both boards. If that counter was part of your traces, then you'd be able to compare the transactions on the two boards. Not sure if it'll help, but at least you'd have better visibility into both ends of the design ...
The other option would be to buy one of the SoC kits that has a PCIe slot and put your FPGA board in that. In that case, you could trace the root-complex and end-point.
Good luck with your debugging! :)
Cheers,
Dave
It might all be down to some very dodgy looking PCIe cabling.
The board doesn't plug directly into a PCIe socket, but it connected by two 'SATA' cables connected header board plugged into the PCIe socket.
And the 40 minute build times don't help the rate of debugging (on a i7 with 8GB memory running Ubuntu).
--- Quote Start ---
--- Quote End ---
Sounds like my kind of hardware setup :) (I use PCIe to SMA breakout cables from SAMTEC)
Can you try running a transceiver toolkit test? You do not need a PRBS pattern generator at the other end, just traffic ... I'm pretty sure you can run TTK over a valid PCIe link, but I have not tried to do that.
--- Quote Start ---
--- Quote End ---
Ha! I hear you on that one ... I script my long compiles so that I can walk away while my machine builds multiple designs ... but that does not help when debugging!
Cheers,
Dave
