17255 Discussions
Signed adder and subtractor
Hi, I don't know if this is the ideal forum to ask, but I hope someone could help me!
I need to make a simple adder and a subtractor, signed (2's complement), with 9-bits in, 10-bits out, really any bits, I'll have to make several different bits adder/subtractor. It can be 2 different entities, one for adder and one for subtractor.
I'm having a problem cause of the overflow, sometimes i have my answer in 8-bits and sometimes in 9-bits.. And I need my answer ALWAYS with 9-bit.
Its a little hard to explain, but I guess you guys that are used to programming knows what i'm talking...if not, please respond and I'll send some examples.
Oh..I'm using VHDL.
Really Thanks!!!
9 bit input, 10 bit output
use ieee.numeric_std package.all; ... signal a: signed (8 downto 0); signal b: signed (8 downto 0); signal c: signed (9 downto 0); ... c <= to_signed(to_integer(a), 10) + to_signed(to_integer(b), 10);
rbuggalho,
I can't implement it now, but thanks for the code.
I even made an overflow detection algorithm before thing in convert to integer and then again to signed.
I'll try it later. Thanks again!
An alternative VHDL implementation with less typing:
c <= resize(a, 10) + resize(b, 10);
Cheers,
Dave
dwh@ovro.caltech.edu
Thank you too!!
I made both codes, but I can't compile either.
I guess I need to convert from std_logic_vector to that signed signal (i've never used that before).
Here's my code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.numeric_std.all; entity adder8 is Port ( a: IN STD_LOGIC_VECTOR(8 DOWNTO 0); b: IN STD_LOGIC_VECTOR(8 DOWNTO 0); c: OUT STD_LOGIC_VECTOR(9 DOWNTO 0) ); end adder8; architecture behaviour of adder8 is signal ta: signed (8 downto 0); signal tb: signed (8 downto 0); signal tc: signed (9 downto 0); begin tc <= resize(ta, 10) + resize(tb, 10); //OR tc <= to_signed(to_integer(ta), 10) + to_signed(to_integer(tb), 10); END behaviour;
I need to atribute ta<=a, tb<=b and c<=tc
Thanks!!
--- Quote Start ---
--- Quote End ---
std_logic_vector is just a vector of bits. You need to convert to unsigned or signed depending on what you want those bits to mean. Eg,
c <= std_logic_vector( resize(signed(a),10) + resize(signed(b),10) );
where signed(a) and signed(b) convert the std_logic_vector a and b inputs to signed, and then resize makes them bigger, the add returns signed, so that result is converted back to std_logic_vector before being assigned to the output c.
Cheers,
Dave
Thanks for the help.
It worked fine!
