I have "copied" a project in quartus and entered a new name for the project by using the wizard. The new name is added to the project but a remnant of the old project name still appears at the top of the Quartus window, as shown in the attached bmp file.
How do I get a project to display the new project name and only that name? Thank You TomLink Copied
The name in project title is the revision name. You can change it by starting a new revision and deleting the old one.
Thank you very much for the reply.
Yes, I believe that you are correct that starting a new revision will change the project name. However, when you start a new revision is it true that all assignments are deleted? I seem to remember this happening to me in the past. Regards Tom- Mark as New
You can create the revision as a copy of an existing one. Strictly spoken, the revision name isn't but an entry in the *.qpf file and a respective *.qsf file with a matching name. So you can edit it also manually, if you prefer.
Thank you much.
Tom
