17263 Discussions
Simulating MegaFunction ROM -- wrong path initialization file
I created a ROM MegaFunction using the MegaWizard and loaded an initialization .hex file. The path stored in the .v is a relative path.
When simulating the design in ModelSim, I get the following error:
# ** Warning: (vsim-3534) - Failed to open file "./sine_rom/RomSin15x14.hex" for reading.# No such file or directory. (errno = ENOENT) : C:/altera/11.0/modelsim_ae/win32aloem/../altera/verilog/src/altera_mf.v(792)# Time: 0 ps Iteration: 0 Instance: /sinegen_jig/sinegen_inst/RomSin_inst/altsyncram_component# ERROR: cannot read ./sine_rom/RomSin15x14.hex.# ** Warning: (vsim-7) Failed to open readmem file "./sine_rom/RomSin15x14.ver" in read mode.# No such file or directory. (errno = ENOENT) : C:/altera/11.0/modelsim_ae/win32aloem/../altera/verilog/src/altera_mf.v(44994)# Time: 0 ps Iteration: 0 Instance: /sinegen_jig/sinegen_inst/RomSin_inst/altsyncram_component
Issuing "pwd" shows that the simulation directory is such that the relative path "./sine_rom/RomSin15x14.hex" is incorrect.
If the .hex file were in the same directory as the quartus project file, then the this supposed bug would be masked, since Quartus II creates a copy of the .hex file in the simulation directory.
Any suggestions to get around this without setting an absolute path or manually recreating the directory structure in the simulation directory?
hi goretkin,
i also faced the same issue,
just create sine_rom folder in your simulation directory and dump all the .mif there and simulate you wont get that error once again.
regards
charan
