Simulating register
Hey I'm having some troubles trying to simulate a memory address register in quartus. I did the register itself using schematic capture and generated a working symbol. Now I'm trying to connect the inputs of the MAR to lines of a bus. I created a bus line and called is BUS[4..15] and then created 12 lines off of it that go to the inputs of the register, titled BUS[4] through BUS[15]. Then I was trying to figure out how to simulate this but I'm not sure how to set values for the bus lines.
