17247 Discussions
Simulation Flow Window Opens and Closes Instantly
I'm using Quartus II 64-Bits 13.0.0 and while simulating my project (opening a .vwf file and then going to Functional Simulation), the "Simulation Flow" window opens and closes instantly right after it appears. Timing simulation doesn't work either, and I can't even get an error report, since there's no way to see if anything is actually written on that window.
Also, I'm using ModelSim ALTERA STARTER EDITION 10.1d and my computer is a Windows 10 Home 64-bit.
The project itself is the simulation of a MIPS ISA, which includes the basic processor instructions in assembly (which were also tested/implemented in a DE2-70 board) as part of my Organization and Architecture of Computers course at my uni.
Thank you.
I believe the Quartus II 13.0 is not supported in Windows 10. Try with Win 7.
--- Quote Start ---
--- Quote End ---
Hmm, well, almost sure other students tried it in Windows 10 and it worked just fine. I'll try reinstalling everything...
