16650 Discussions
Simulation of Electric Machines on FPGA Board
Dear all,
I would like to put the electric machine model into the Cyclone II FPGA since it will give us much more faster simulation performance.
Can anyone share me some experience to put the electric machine model into FPGA?
Thanks!
Which electrical machine model are you refering to? have you got a compiled design?
--- Quote Start ---
--- Quote End ---
For example, induction machine. At this moment, I do not have a compiled model. The trick part is to how to realize the induction motor model in VHDL
You would not write an induction motor in VHDL - it is an electrical device that uses magnets to propell a motor - Do you mean the controller for such a device?
--- Quote Start ---
--- Quote End ---
I found a paper to describe how to implement. Can you give me some comments? Thanks.
Its a model of a complex system. Im sure it can be written in VHDL given enough time and effort. What other comments do you want?
I don't see a particular advantage of running electrical machine simulations on FPGA, although it's surely possible. I can report of a commercial machine emulator that is running the (nonlinear) motor model with 50 µs simulation step on a performance microprocessor. http://www.scienlab.de/file_622-125468-890/scienlab-inverter-test-environment.pdf
