17261 Discussions
Simulation time settings.
Hi
Can anybody help me regarding to simulation time seetings..
For example..I am using clocked input so that by increase the simulation time all the inputs can be entered...
I m Using Quartus II 7.2 Web edition.
regards
Hasan
This is probably not going to help much, I think you need to be more clear. Do you mean you want to have a serial input, so that each cycle one portion of the input data is entered?
Hi..
yes..
I have taken few input as clocked input..
So I want do some process using that input...
Therefore, can anybody help me how I can increase the simulation time so that i can take more clocked (synchronize) input..and process that input and finally I can show that output within the simulation time..
thank you for your help
You mean the simulation time setting in waveform editor?. It's Edit menu: End Time.
Hi....
Yes how can I setting the wave form for increase the simulatuion time..??
So that I can process the input and show the output within the simulation time
You can either set the end time, or advance the time as you want using the "run" command.
