17263 Discussions
Simulation using ModelSim
Hi..
i am simulating a project using modelsim i am facing some problems
1. i have written a test bench for my simulation and assigning some data at input port witch is 8bit wide and suppose to receive packet of data which is 53bytes long
2. when i am trying to input a data it is accepting only one byte at a time
3.how to input a data which is a packet of 53bytes to my input port.
please help me
thank you
well post some code and your testbench and we'll see.
With a testbench you can do a load of stuff you cannot do in synthesisable VHDL, so its very easy to control data flow.
Dear sir here is the code for test bench....
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
LIBRARY lpm;
USE lpm.lpm_components.ALL;
LIBRARY work;--(i added this library)
USE work.voq_input_package.ALL;
entity voq_switch_tb is
end voq_switch_tb;
architecture tb of voq_switch_tb is
component voq_switch is
PORT (
fp1 : IN STD_LOGIC; --input frame pulse lines
fp2 : IN STD_LOGIC;
fp3 : IN STD_LOGIC;
fp4 : IN STD_LOGIC;
data_in1 : IN BYTE; --input data byte lines
data_in2 : IN BYTE;
data_in3 : IN BYTE;
data_in4 : IN BYTE;
global_reset : IN STD_LOGIC; --Resets all the counters,registers and the buffer
reset : IN STD_LOGIC; --Resets everything but the buffer
clock : IN STD_LOGIC;
fp_out_port1 : OUT STD_LOGIC; --output frame pulse lines-
fp_out_port2 : OUT STD_LOGIC;
fp_out_port3 : OUT STD_LOGIC;
fp_out_port4 : OUT STD_LOGIC;
data_out_port1 : OUT BYTE; --output data_lines
data_out_port2 : OUT BYTE;
data_out_port3 : OUT BYTE;
data_out_port4 : OUT BYTE;
data_valid1 : OUT STD_LOGIC; --output data_valid lines
data_valid2 : OUT STD_LOGIC;
data_valid3 : OUT STD_LOGIC;
data_valid4 : OUT STD_LOGIC;
--Source port number
incoming_port_to_output1 : OUT STD_LOGIC_VECTOR (2
DOWNTO 0);
incoming_port_to_output2 : OUT STD_LOGIC_VECTOR (2
DOWNTO 0);
incoming_port_to_output3 : OUT STD_LOGIC_VECTOR (2
DOWNTO 0);
incoming_port_to_output4 : OUT STD_LOGIC_VECTOR (2
DOWNTO 0);
--Priority vector output for simulation purpose
P : OUT STD_LOGIC_VECTOR (7 DOWNTO 1);
--request to scheduler and grant coming from scheduler for simulation
request : OUT STD_LOGIC_VECTOR(16 DOWNTO 1);
grant : OUT STD_LOGIC_VECTOR(16 DOWNTO 1)
end component;
signal fp1: STD_LOGIC:='0';
signal fp2: STD_LOGIC:='0';
signal fp3: STD_LOGIC:='0';
signal fp4: STD_LOGIC:='0';
signal data_in1,data_in2,data_in3,data_in4: BYTE:="00000000";
signal global_reset: STD_LOGIC:='0';
signal reset : STD_LOGIC:='0'; --Resets everything but the buffer
signal clock : STD_LOGIC:='1';
signal fp_out_port1 : STD_LOGIC:='0'; --output frame pulse lines-
signal fp_out_port2 : STD_LOGIC:='0';
signal fp_out_port3 : STD_LOGIC:='0';
signal fp_out_port4 : STD_LOGIC:='0';
signal data_out_port1 : BYTE:="00000000"; --output data_lines
signal data_out_port2 : BYTE:="00000000";
signal data_out_port3 : BYTE:="00000000";
signal data_out_port4 : BYTE:="00000000";
signal data_valid1 : STD_LOGIC:='0'; --output data_valid lines
signal data_valid2 : STD_LOGIC:='0';
signal data_valid3 : STD_LOGIC:='0';
signal data_valid4 : STD_LOGIC:='0';
signal incoming_port_to_output1 : STD_LOGIC_VECTOR (2 DOWNTO 0);
signal incoming_port_to_output2 : STD_LOGIC_VECTOR (2 DOWNTO 0);
signal incoming_port_to_output3 : STD_LOGIC_VECTOR (2 DOWNTO 0);
signal incoming_port_to_output4 : STD_LOGIC_VECTOR (2 DOWNTO 0);
signal P : STD_LOGIC_VECTOR (7 DOWNTO 1);
signal request : STD_LOGIC_VECTOR(16 DOWNTO 1);
signal grant : STD_LOGIC_VECTOR(16 DOWNTO 1);
constant num_cycles : integer := 320;
begin
U_voq_switch:voq_switch port map(
fp1,fp2,fp3,fp4,
data_in1,data_in2,data_in3,data_in4,
global_reset,
reset,
clock,
fp_out_port1,fp_out_port2,fp_out_port3,fp_out_port4,
data_out_port1,data_out_port2,data_out_port3,data_out_port4,
data_valid1,data_valid2,data_valid3,data_valid4,
incoming_port_to_output1,incoming_port_to_output2,incoming_port_to_output3, incoming_port_to_output4,
P,
request,
grant
-- architecture declarative part
-- constant num_cycles : integer := 320;
--signal clock : std_ulogic := '1';
-- architecture statement part
process
begin
--for i in 1 to num_cycles loop
for i in 1 to 100 loop
clock <= not clock;
wait for 10 ns;
clock <= not clock;
wait for 10 ns;
-- clock period = 10 ns
end loop;
wait; -- simulation stops here
end process;
-- concurrent process to offer clock signal
--process
--begin
--clock <= '0';
-- wait for 5 ns;
-- clock <= '1';
--wait for 5 ns;
-- end process;
process
variable err_cnt:integer:=0;
begin
-- case 1
fp1 <= '1';
wait for 20 ns;
fp1<='0';
wait for 10 ns;
data_in1 <= "00000110";
wait for 20 ns;
data_in1 <= "00000111";
wait for 20 ns;
data_in1 <= "00001000";
wait for 20 ns;
data_in1 <= "00001001";
wait for 20 ns;
data_in1 <= "00001010";
wait for 20 ns;
data_in1 <= "00111010";
-- assert (data_out_port1="11111111") report "Sum Error!" severity error;
--assert (carry='0') report "Carry Error!" severity error;
-- if (data_out_port1/="01010101" ) then
-- err_cnt:=err_cnt+1;
-- end if;
-- summary of testbench
if (err_cnt=0) then
assert false
report "Testbench of Adder completed successfully!"
severity note;
else
assert true
report "Something wrong, try again"
severity error;
end if;
wait;
end process;
end TB;
configuration CFG_TB of voq_switch_tb is
for TB
end for;
end CFG_TB;
you need to add more data to the second process. I also suggest making it sensitive to clock rather than waiting for time periods between inputs.
