17254 Discussions
Simulation waveform Editor error
choboja
Hi, I had a problem studying verilog alone
The basic code was compiled well as shown in the picture below.choboja_0-1690341609389.png
Next, I simulated it, but all the code was completed successfully, but at the end, an error occurred without any explanation.
Below is the full text of the simulation flow progress.
Determining the location of the ModelSim executable...
Using: c:/intelfpga_lite/22.1std/questa_fse/win64/
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both Questa Intel FPGA Edition and ModelSim executables are available, Questa Intel FPGA Edition will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off AlteraProject -c AlteraProject --vector_source="C:/VerilogHDL/test/Waveform.vwf" --testbench_file="C:/VerilogHDL/test/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 22.1std.1 Build 917 02/14/2023 SC Lite Edition
Info: Copyright (C) 2023 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Wed Jul 26 12:24:40 2023
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off AlteraProject -c AlteraProject --vector_source=C:/VerilogHDL/test/Waveform.vwf --testbench_file=C:/VerilogHDL/test/simulation/qsim/Waveform.vwf.vt
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the timing simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory="C:/VerilogHDL/test/simulation/qsim/" AlteraProject -c AlteraProject
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory=C:/VerilogHDL/test/simulation/qsim/ AlteraProject -c AlteraProject
Info (204019): Generated file AlteraProject_8_1200mv_85c_slow.vo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject_8_1200mv_0c_slow.vo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject_min_1200mv_0c_fast.vo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject.vo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject_8_1200mv_85c_v_slow.sdo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject_8_1200mv_0c_v_slow.sdo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject_min_1200mv_0c_v_fast.sdo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info (204019): Generated file AlteraProject_v.sdo in folder "C:/VerilogHDL/test/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 4659 megabytes
Info: Processing ended: Wed Jul 26 12:24:41 2023
Info: Elapsed time: 00:00:01
Info: Total CPU time (on all processors): 00:00:00
**** Generating the ModelSim .do script ****
C:/VerilogHDL/test/simulation/qsim/AlteraProject.do generated.
**** Running the ModelSim simulation ****
c:/intelfpga_lite/22.1std/questa_fse/win64//vsim -c -do AlteraProject.do
Error.
I appreciate a little help. Thanks.
ShengN_Intel
Tested without problem from my site check the screenshot and file attached. May be try to recreate the project.
Note 1: In vwf, goto Simulation -> Simulation Settings -> Timing Simulation Settings -> delete -novopt -> save.
Note 2: If you don't get output waveform, try to use older device because vwf is legacy simulator for older device.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer
ShengN_Intel
Any further update or concern from your side?
