17249 Discussions
Slack:Not operational: Clock Skew>Data Delay ...
Hi All,
In Quartus II,
the classic timing analysis report shows:
Slack:Not operational: Clock Skew>Data Delay,
but,when i download the whole design to the fpga,
it can works without any error.
meanwhile, when i right-click the red information in the report
and chose "locate in RTL viewer" , could see the two register
use two different clock, which is right a part of the design.
i don't think this situation should be analyzed with the regulation
of "clock hold analysis" ,for the two register use different clock.
but how should i deal with the error information (with red color)
in the classic timing analysis report?
Thank you!
--- Quote Start ---
Hi All,
In Quartus II,
Thank you!
--- Quote End ---
that means you have a clock domain crossing here. Connecting the register simply together will not work in all cases. There is a lot of stuff in the forum regarding clock domain crossing.
Kind regards
GPK
Gerd
Pletz,thank you for your reply.
the rtl view image shows in this link web:
http://hi.baidu.com/cowoho/album/item/96120d3304ed38d91b4cff5a.html
it seems not a example that should be analyzed with the regulation of "clock skew< or > data delay", but in the Quartus II software,it was judged to "clock > data delay",in the classic timing analysis report table with red color.when right-click the red information in the report and chose "locate in RTL viewer" ,we could see the image like above.
i want to ask:is this design showed in the image reasonable&#65311;i think if "clk1/clk2" could fit "data1/data2" in timing, there should not be errors in this part, really? and, if yes,could i neglect the warn of quartus?
waiting for help...thanks!
