17267 Discussions
Some questions about Active Serial Memory interface
when I added the Active Serial Memory interface to a SOPC project in QuartusII8.0 version,the warning information appered.How can I resolve the problem?
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "endofpacket"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "data_from_cpu"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "write_n"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "irq"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "asmi_select"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "read_n"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "dataavailable"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "data_to_cpu"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "clk"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "mem_addr"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "reset_n"
Warning: asmi_classic_1: The instancePtf parameter has 2 ports named "readyfordata"
Warning: asmi_classic_1: Multiple ports named: clk (asmi_control_port_clock.clk and asmi_classic_1_control_port_clock.clk)
Warning: asmi_classic_1: Multiple ports named: reset_n (asmi_control_port_clock.reset_n and asmi_classic_1_control_port_clock.reset_n)
Warning: asmi_classic_1: Multiple ports named: asmi_select (asmi_control_port.chipselect and asmi_classic_1_control_port.chipselect)
Warning: asmi_classic_1: Multiple ports named: data_from_cpu (asmi_control_port.writedata and asmi_classic_1_control_port.writedata)
Warning: asmi_classic_1: Multiple ports named: data_to_cpu (asmi_control_port.readdata and asmi_classic_1_control_port.readdata)
Warning: asmi_classic_1: Multiple ports named: dataavailable (asmi_control_port.dataavailable and asmi_classic_1_control_port.dataavailable)
Warning: asmi_classic_1: Multiple ports named: endofpacket (asmi_control_port.endofpacket and asmi_classic_1_control_port.endofpacket)
Warning: asmi_classic_1: Multiple ports named: mem_addr (asmi_control_port.address and asmi_classic_1_control_port.address)
Warning: asmi_classic_1: Multiple ports named: read_n (asmi_control_port.read_n and asmi_classic_1_control_port.read_n)
Warning: asmi_classic_1: Multiple ports named: readyfordata (asmi_control_port.readyfordata and asmi_classic_1_control_port.readyfordata)
Warning: asmi_classic_1: Multiple ports named: write_n (asmi_control_port.write_n and asmi_classic_1_control_port.write_n)
Warning: asmi_classic_1: Multiple ports named: irq (asmi_control_port_irq.irq and asmi_classic_1_control_port_irq.irq)
Info: cfi_flash: Flash memory capacity: 32.0 MBytes (33554432 bytes).
